Author Topic: stuck in 4wd?  (Read 1859 times)
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
stuck in 4wd?
« on: Nov 10, 2005, 03:08:55 PM »
Alright, supermat asked me to post this, as he is not around a computer at the moment.
His truck is in 2wd, and his hubs are unlocked.  However, his front driveshaft is still turning.  Ie has IFS, his front is locked, and he doesnt have dual cases, he's got a 1989 extended cab pickup, very similar to mine.  My guess is that for some reason, one or both of the hubs didnt disengage all the way :dunno:  anyone else?
              -Ronald Reagan
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: stuck in 4wd?
« Reply #1 on: Nov 10, 2005, 03:18:31 PM »
Either that or he is still in 4wd.
Those would be your only 2 options.
Have him lock the hubs again and burnout, that way he can see if he is "stuck in 4wd"
If the front doesn't peel, then it is a hub problem.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: stuck in 4wd?
« Reply #2 on: Nov 10, 2005, 05:13:53 PM »
yea  he should try and make sure the hubs are actually unlocking,  did they click ,  mine kinda click when they unlock
probably a little corrosion in the lockout
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Member since Oct '04
  • Proud Parent
Re: stuck in 4wd?
« Reply #3 on: Nov 10, 2005, 06:22:39 PM »
pull the 10mm bolts  off and see if the hub springs out at ya, if it does its still locked... lol
could be a hub malfunction or just got stuck, work them back and forth a little see if it clicks out. Or drive it around for a few min's and stop/ twist the hub lock back and forth until it lets go.
We had that problem on bigbluewillys truck coming out of the Con, spun the driveshaft a little and cranked the hub locks back and forth a few times.
Ramrod
  • smelling like vag and loving it
  • Turtle Points: -59
  • Male Posts: 3,600
  • fully bodied & Fully getting it
Re: stuck in 4wd?
« Reply #4 on: Nov 10, 2005, 08:44:49 PM »
it turns out my hub was stuck like that cause the gear that is supposed to slide in and out to engage 4wd was shattered and not all of it was coming out with the spring so maybe that is what is wrong with yours.  Like shamb said to get it undone we moved the driveshaft around and turned the hub at the same tiime and it came undone
BLACKDOG [OP]
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
Re: stuck in 4wd?
« Reply #5 on: Nov 10, 2005, 09:30:33 PM »
I know supermat's hubs are shot, so that is my guess.  I'm not with him, he's out fishin, and he left me a message, so I dont know all the details.  Thanks for the help :thumbs:
              -Ronald Reagan
MidgetMike
  • Turtle Points: 55
  • Male Posts: 668
  • Member since Sep '04
  • My 83 soon to be the sh%*
Re: stuck in 4wd?
« Reply #6 on: Nov 14, 2005, 07:50:55 PM »
If he is locked up front the t case may be bound up try backing up slowly in 2 wheel drive when dissengaging
Last post Apr 19, 2006, 09:01:43 PM
by 85Flatty
Last post Aug 25, 2008, 07:34:06 AM
by 83MT
Last post Nov 24, 2009, 02:45:42 PM
by swapped89
Last post Dec 02, 2009, 11:56:25 AM
by b-radhutch
Last post Apr 03, 2010, 07:49:07 PM
by 89bogger
