So, if I put the stock rear springs up front, do I have to add more leaves to get the lift I want. I know those will move the front axle 2" forward and that should help with my firewall clearance I need. I will also have to weld on part of an old spring pack to the right side spring perch to get it to sit level, correct? I took a look at my '85 and it doesn't look like I can drill the front spring perch forward 1 1/2". Was yours a SAS conversion joez? or were you possibly talking about relocating the centering pin on the springs themselves?
Started by Doc Holiday Engine
Started by -Matt- « 1 2 » Project Research and Build-Ups
Started by KDXSR5 « 1 2 3 4 » Toyota Pickup/4Runner Tech 1979-95
Started by ZombieHunter Parts Wanted
Started by Aaronm Toyota Pickup/4Runner Tech 1979-95
