Author Topic: dual cases on a g58 trany?  (Read 1904 times)
yota-tota
  • Turtle Points: 17
  • Male Posts: 232
  • Member since Oct '05
  • Crawling over Marlin
« on: Oct 04, 2005, 01:08:55 PM »
i got a 91 toyota pickup and i know i have a chain driven t-case but i was wondering if i can take that t-case out and swap in two gear driven transfer case  for a dual case setup? also wondering if i should upgrade my gearing or go dual cases with 4.7 in the rear when i go from 33's to 36's? i have 4.10's now
91 toy truggy on h2 injection, hacked n chopped n locked n SAS'd rolling 36" IROKS........doubler comming soon
FIREBALL
  • Turtle Points: 190
  • Member since Feb '03
  • Hi Ho Marlin....u talkin to me
Re: dual cases on a g58 trany?
« Reply #1 on: Oct 04, 2005, 02:11:38 PM »
If, your tranny is a g58, then you must have a 4cyl and in that case you have a gear driven t-case. So doing a dual or changing gears is no prob.
If you have a V6 then you have an R150 and then yes with an additional adapter you can convert to a gear driven case with all the same options.
When you go from 33's to 36's you will want to change your r&p too. The t-case gears won't help you on the street, only when you're in low range. 5.29's are just about right for 36's.
Here's a little more info....
http://www.marlincrawler.com/trans.html
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
« Reply #2 on: Oct 04, 2005, 09:49:26 PM »
Oh no no, I'm pretty sure I've had this talk with Marlin a couple of times as I wanted to upgrade my g58, and was told it's chain driven.  I seem to remember seeing a thread on a g58 recently and he said he was building an adapter to run duals on it.
yota-tota [OP]
  • Turtle Points: 17
  • Male Posts: 232
« Reply #3 on: Oct 05, 2005, 10:26:15 AM »
my truck is a 4 banger but it doesn't have gear driven t-case..........i counted the bolts on the output case and 7 = gear t-case and i had 10 i think.
FIREBALL
« Reply #4 on: Oct 05, 2005, 01:21:42 PM »
Chain drive cases only have 5 bolts. You may be counting the wrong bolts. Look at the pictures here.
http://www.marlincrawler.com/tcaseinfo.html
If your case looks like this one you're ok. The chain drive cases look very differant from the gear drive. (kinda flater on the back)
yota-tota [OP]
  • Turtle Points: 17
  • Male Posts: 232
« Reply #5 on: Oct 05, 2005, 01:59:12 PM »
well it has 5 bolts......i don't where i got 10 it
s been too long since i've driven my truck as it's on the way across canada.
motorider228
  • Turtle Points: 433
  • Male Posts: 460
  • Member since Apr '05
« Reply #6 on: Oct 05, 2005, 03:16:35 PM »
some 4 bangers come with a g58 tranny which is a chain driven case, there fore you must run a special adapter and gear driven cases for dual cases. my 93 runner has a 22re and a g58. so its hard for me to run dual cases.
Last post Aug 07, 2002, 04:57:01 AM
by BigMike
Last post Apr 28, 2003, 03:22:44 AM
by trdvet
Last post Jul 27, 2003, 09:11:14 PM
by BigMike
Last post May 07, 2012, 08:17:08 AM
by MT4Runner
Last post Mar 14, 2024, 10:50:48 PM
by Intimidatorj710
