Reply #1 on: Oct 03, 2005, 08:53:14 PM »
It sounds like you have a missing ground.
All turbo Runners were autos, and only came with the ditigal dash.
With out the cluster proprely grounded, it will search for a ground, even going thur other circuts to find it.
Remove the cluster, and check the plugs for missing grounds, and then examine the circut board for loose or broken connections.
![](https://board.marlincrawler.com/Themes/MCI_V3C/images/ip.gif)
Logged
