Author Topic: 22re cutting out  (Read 4523 times)
seanc
  • Turtle Points: -357
  • Male Posts: 347
  • Wheeler For Life!
22re cutting out
« on: Oct 02, 2005, 01:57:47 PM »
hello all i have a 1985 toyota 22re in my truck, while it is cold it will run mostly fine, a little more rich than normal though, but when it gets warm, it will start cutting out under load, you will be on the gas and it will die then about 1 second later it will come back then die. when not under load it will rev fine. also when its warm fuel will leak out of the canister on the passenger fender, out of the tube on the bottem, but when its cold it won't. also it is pulling code 11. which is switch signals i am stumpted thanks.
You win some, you lose some.
FATTshack
  • Turtle Points: 129
  • Male Posts: 316
  • Member since Jun '05
  • BLUEY the WONDERSLUG
    • The FATT Shack
Re: 22re cutting out
« Reply #1 on: Jan 22, 2007, 05:41:02 PM »
BTT same problem here....any suggestions?
Hyena
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #2 on: Jan 22, 2007, 05:47:22 PM »
check the timing.  when i did my timing chain i didn't have my timing checked yet and it did pretty much the same thing.  standing still it would rev up fine but under load it would cut out but not quite die.  got it timed and it is good now.  at least you could start there.
FATTshack
  • Male Posts: 316
    • The FATT Shack
« Reply #3 on: Jan 22, 2007, 07:34:16 PM »
rgr that. We have so much going on with this motor, I don't even know were to start...LOL
  • Turtle Points: 1615
  • Male Posts: 18,046
  • Member since Apr '02
  • 511:1 Club
« Reply #4 on: Jan 22, 2007, 07:47:35 PM »
First the #1 thing you want to do is either replace your purge canister or somehow drain it.
My friend's MR2 would not pass smog, and we worked and worked and worked at it, and finally found out that his purge canister was full of gas, maybe because he topped off his tank one too many times.
If there is gas in your canister, then it can easily be sucked into the engine and run it rich. When this rich mixture makes its way to your oxygen sensor, it will tell the ecu to lean out the mixture. But remember that the mixture is correct, but its just the added gas from the canister that is sending the wrong signal to the ecu.
If it is really rich then the ecu can very well pull plenty of fuel out and you would loose a lot of your power.
What happens if you keep your foot in it when it cuts out? If you keep the throttle WOT (wide open), then the manifold vacuum might be low enough as to not suck gas from the canister. Of course I recommend draining the fuel from there first, but you could try this to test the theory.
New Instagram: @SlowestTacoma
2016 56-speed 580:1 Triple T/Case 3rd gen Tacoma Rock Crawler
FATTshack
  • Male Posts: 316
    • The FATT Shack
« Reply #5 on: Jan 23, 2007, 07:04:34 PM »
I think it was the timing. its a buddies truck and he live an hour from me, so I can only work on it during the weekends. I called him and told him to see what the timing was set at. he replied 22^ BTDC...LOL . We forgot to set the timing after we got it running... and after we got it out on its first run we noticed the problem.
Its one of those "I thought you set the timing......No I though YOU set the timing"....LOL
  • 511:1 Club
« Reply #6 on: Jan 23, 2007, 10:45:33 PM »
Glad you guys got it fixed, but I would still look into the purge canister. It is not supposed to be full of gasoline.
FATTshack
  • Male Posts: 316
    • The FATT Shack
« Reply #7 on: Jan 24, 2007, 03:40:15 PM »
I don't think I have any fuel in ht can... that was the other dude.
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,324
  • Member since Jul '05
« Reply #8 on: Jan 25, 2007, 08:06:56 AM »
I remember when I built the motor on my '87 2wd 22re.  I got a couple of vaccum lines backwards and fuel started dumping out the charcoal canister on hot days, with or without it running.  If you've done some work to it recently, I would definately check the routing of your vaccum lines.  This also caused it to spit, sputter and die.
« Last Edit: Jan 25, 2007, 10:36:27 PM by BUDDERS »
  • 511:1 Club
« Reply #9 on: Jan 25, 2007, 06:56:41 PM »
:slap: <-- BigMike
fordh8r
  • Turtle Points: 803
  • Male Posts: 2,584
  • Member since Jan '07
« Reply #10 on: Jan 26, 2007, 12:29:00 AM »
  I have an  :idea:  :flamer:  :attention:  :gap:
Last post Jun 27, 2006, 09:34:25 AM
by Weldo
Last post Jan 18, 2008, 06:53:59 PM
by kneedownnate
Last post Oct 08, 2008, 07:22:43 PM
by Rix86
Last post May 25, 2009, 03:11:08 PM
by lilstomper
Last post Aug 26, 2012, 08:52:34 AM
by OOPS
