what do you need the tires for??? I got a set here at my shop off the samurai. they are on 15x8 with the same lug pattern as your bronco
not bfg's they are pro comp m/t's they have about 20% tread on them but need to be pulled off the wheels, you can have them all for 50 bucks, the wheels you can keep, one wheel needs the valve stem hole welded up, and a new one drilled in it, but you can put the wheels on something else I am sure. the sammi is still running the bfg's, we need to push the axle another inch forward to get the 35's to fit a little better.
I also got some 31" wranglers on 15" aluminum stock toyota wheels that would fit your junk, and look pretty slick.
I have a tire groover to use on the a/t's.
ideal heated knives, pick em up at tognotti's for about 65 bucks. it was in woodland I let my frined borrow it, he moved to bradshaw and 50, so next time I go to the drive in's i'll grab it.
$65 Hmmm, not bad I might have to go get one. How well does the groover work? Does it come with different sized blades? Sorry for the thread jack FFC.
are you interested in the tires?
Started by wheeloverhondas « 1 2 » Engine
Started by CruzrDave Engine
Started by grumpy1@netptc.net Parts For Sale
Started by toyofan7987 Parts For Sale
Started by monyman Parts For Sale
