Author Topic: SR5 Instrument Cluster Instal Help.  (Read 6283 times)
chim
  • Turtle Points: 1254
  • Male Posts: 1,258
  • Member since Apr '05
  • www.infowars.com
« on: Sep 22, 2005, 10:00:45 AM »
I need help wiring this dash in..  its an sr5 dash going into a standard 4runner..  How do yo uhook the tach and the oil pressure up.. and does the temp and fuel work with the factory harness connections??  Thanks
ToyDozer
  • Turtle Points: -3
  • Male Posts: 15
  • Member since May '05
Re: SR5 Instrument Cluster Instal Help.
« Reply #1 on: Sep 22, 2005, 05:50:41 PM »
Umm, this maybe oversimplifying things but here goes anyhow.
Take original cluster out of dash.......
Plug in the new cluster just like the old cluster was plugged in.......
Swap in the oil pressure sending unit in place of the oil pressure switch, the plugs are the same so plug and play.
And last but not least, fire it up and enjoy your new dash....
Jon Stensaa
ToyDozer@ACSAlaska.net
Accelerator : The stomped out hole in the floarboard!!!!
luigi
  • Turtle Points: 21
  • Member since Apr '03
  • The more dents I get the more fun I have.
« Reply #2 on: Sep 22, 2005, 06:25:22 PM »
X2  piece of cake, make sure you change the sending unit on the block or you Will fry the oil pressure guage.  Ask me how I know,  Doh! :hammerhead:
85 4 Runner
22RE Auto to 5speed swap
Marlin Crawler Dual Ultimate Case
5.29s
Arb's front and rear
Rapidly denting away my "Mall Runner Status"
chim [OP]
  • Male Posts: 1,258
  • www.infowars.com
« Reply #3 on: Sep 23, 2005, 07:26:22 AM »
Will the tach just work off of the factory non SR5 harness???  If it does..   sweet!!
Skinny_Pedal
  • Turtle Points: 89
  • Male Posts: 2,833
  • Member since Apr '04
  • work so I can support my lifestyle
« Reply #4 on: Sep 23, 2005, 11:13:08 AM »
 :thumbs:
Im an OG
chim [OP]
  • Male Posts: 1,258
  • www.infowars.com
« Reply #5 on: Sep 23, 2005, 11:20:15 AM »
those japanese thought of everything!!!
Plowking
  • Turtle Points: -75
  • Male Posts: 504
  • Member since Jan '05
  • Awesome yota
    • Buy me a drink
« Reply #6 on: Sep 23, 2005, 07:33:48 PM »
I remember on my non Sr5 86 I had to run 1 wire to the tach feed back to the negative side of the coil (on carburated 86 model)
2008 Dodge Diesel  (Cummins Rule)
6.7 manual quad 8 foot bed H&S delete, banks air box
93 yota 3.0 locked up...
2004 Yamaha Raptor 660R
84toyota
  • Turtle Points: 44
  • Member since Dec '04
« Reply #7 on: Sep 24, 2005, 03:44:53 PM »
More than likely, you'll have to run a wire from the "capped" plug which comes off the negative side of the coil.  That will power the tach, as many have mentioned already.  As my memory recalls, I had to swap the location of one of the other wires (repin it) for maybe the temperature guage.  Does sound right to those of you who have done the swap?  I know I had to repin one of the wires...  AND YES - please make sure you use the proper oil pressure sender, not the idiot light switch type...
Ken
chim [OP]
  • Male Posts: 1,258
  • www.infowars.com
« Reply #8 on: Sep 26, 2005, 07:26:04 AM »
It was plug and play fella's.. awesome.. the only thing i have to do is get the correct oil pressure sending unit... tach and all other gauges worked perfect.. thanks for the help!  :D
reklund5
  • Turtle Points: 286
  • Male Posts: 1,263
  • Member since Nov '03
  • I love my Marlin Crawler!
« Reply #9 on: Sep 26, 2005, 05:20:01 PM »
You've unplugged your existing oil sending unit, correct?  DO NOT leave it plugged in with your fancy new SR5 cluster installed.
chim [OP]
  • Male Posts: 1,258
  • www.infowars.com
« Reply #10 on: Sep 27, 2005, 07:40:58 AM »
NO.. I left it unplugged...  i remember something about burning it up.. so its unplugged .. thanks.
Last post Nov 30, 2004, 08:46:13 PM
by FATB0Y
Last post Jul 10, 2008, 12:15:09 PM
by 83MT
Last post Oct 11, 2020, 11:43:02 AM
by Groundpounder17
Last post Dec 14, 2019, 11:54:33 AM
by mwhite49
Last post Sep 13, 2020, 04:26:08 AM
by Gnarly4X
