TECH: How I built my square driveshaft
Started by MiniSimp, September 14, 2005, 01:04:44 PM
NorCalToy
Going out to start mine now. Thanks Mini I read both the eHow and here. :thumbs:
:flamer: IFS
85yotapolo
ok little confused on how to measure to get the right amount of tubing i will need....
anyone explain it better??
BoG-ToY
harbor freight carrys an 18" receiver tube (if your going 2") thats really all you need for the ONE side.
for the other side really, what I would do... is compress your front end as much as possible and measure how much tube you would need and cut off an inch or two (just  in case you compress FARTHER then what you did... then lift the truck up, let the axle droop and make sure you would still have plenty of engagement.
Maybe someone else can give you more info, I did mine, it worked great and it was VERY simple.
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
4runner freak
Quote from: 85yotapolo on February 10, 2010, 12:10:09 PM
Build it long, cut it to fit.
1. Measure distance from flange to flange,(A)
2. Measure from flange to cv(B) and flange to u-joint(C)
3. Subtract B and C from A= D
4. Make each piece at least as long as D and weld it up.
5. After it is welded up, put it together.
6. Take dimension A, subtract how much compression you want(E) and cut each piece to make the overall compressed length = A-D
Clear as mud?
Finally got my '85 4runner!
Let the buildup begin!
Working on DUAL-TRANNYS
http://www.pirate4x4.com/forum/showthread.php?t=862345
85yotanh
am I right in assuming that in 2wd there wouldnt be any vibrations?
BoG-ToY
hubs unlocked... tcase in 2wd the shaft is idle..... hubs locked or tcase in 4wd, some vibes... faster you go the worse they are... lol
NorCalToy
my shaft is good to 55 or so if im on the throttle. when im coasting its gets bad around 40-45.
:flamer: IFS
YERF
Is it just not even worth it to build one with a later model CV?
BoG-ToY
grind it out and make it an early model one?
yjay
Mine is cv.
Why would this not be preferable?
Minisimp's example is cv.  :dunno:
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
BoG-ToY
he said late model CV, they were mated to a fixed IFS diff, so although they are limited on droop, you have to remove the tight spots with a rotary file
yotatough
I always run 2 standard u joints, never had a real problem without the cv in there
wakkjobb
+1; regular U-joints work well so far... CV for rear shaft, yes.
:twocents:
>>Dan
yotatough
yeah I run the cv in the rear, my front is good up to 55mph so far.
BoG-ToY
sometimes I think its use what you have?
also, you have to change flanges too
Zane
can you swap out a 2nd gen front shaft on a first gen? does it bolt up?
84_yota_4wd
This thread helped me in 2014 almost 10 years later. Now that's cool
Marlin Crawler
Developers of the longest lasting and most successful
Toyota Transfer case, Transmission, and Differential products on the planet
(888) 94-CRAWL / 888-942-7295
