Reply #3 on: Aug 28, 2005, 09:30:39 AM »
Also check for floor boot bind.
We have had a lot of problems with the handle being in a bind when shifted into low range.
Check for broken motor mounts, loose bellhousing bolts, rusted or frozen rear driveline slip yoke.......
Logged
