Author Topic: A/C Question  (Read 1648 times)
paradisekid
  • Turtle Points: -93
  • Male Posts: 38
  • Member since Feb '05
A/C Question
« on: Aug 05, 2005, 12:44:20 PM »
On my 85 4runner (22re) the first two a/c settings don't work, but on levels 3 and 4 the a/c works fine.  Are there individual fuses for each setting?  Any help would be appreciated.
FIREBALL
  • Turtle Points: 190
  • Member since Feb '03
  • Hi Ho Marlin....u talkin to me
Re: A/C Question
« Reply #1 on: Aug 05, 2005, 12:47:09 PM »
Is it just when the ac is on, or does it do the same thing with the heater too? May be the blower switch is bad.
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
Re: A/C Question
« Reply #2 on: Aug 05, 2005, 12:48:45 PM »
check the fuse that is physically on the fan motor, you can access it if you pull the glove box all the way down to the floor, its covered by a small black cover, should be a 15 amp, if not, then the fan itself has become coroded on the low speed settings, remove, clean, reinstall, or replace it--hope this helps
Prismo
  • Turtle Points: 8428
  • Member since Oct '03
  • Living in the green house
Re: A/C Question
« Reply #3 on: Aug 05, 2005, 01:00:22 PM »
If it is the fan that will only run at certain settings, it is the resistor that has gone bad. It is located under the glove box on the housing around the heater core as I remember.
paradisekid [OP]
  • Male Posts: 38
Re: A/C Question
« Reply #4 on: Aug 05, 2005, 01:30:31 PM »
Thank you for the input.......both the heater and a/c don't work on the first two settings.  I will plan on replacing the resistor.  Have a great weekend. :beer:
Last post Apr 20, 2003, 04:06:00 PM
by 84runner
Last post Jul 19, 2004, 03:13:47 PM
by robrocketanski
Last post Feb 27, 2005, 12:16:30 PM
by Weldo
Last post Apr 08, 2005, 07:16:22 AM
by mr4x42u
Last post Dec 31, 2005, 02:51:23 PM
by 6.72:1
