Author Topic: springs  (Read 1669 times)
k20
  • Male Posts: 55
  • Member since Jul '05
springs
« on: Jul 08, 2005, 05:07:19 AM »
im planing on doing a rear chevy spring conversion,and ive read that alot of people put the rear spring pack in the front.i know the centre bolt is offset so it moves the front axle forward to give the tire more clearance,but is this the only reason?are the rear leaves longer than the front?how many leaves do you run?my rear pack has got 5 leaves + the over load.thanks for the help,
later!
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: springs
« Reply #1 on: Jul 08, 2005, 06:57:59 AM »
later!
The springs are longer, softer, really flexy, and move the axle 2" forward.
Here is everything you always wanted to know about "Rears up front" but were afraid to ask: http://www.pirate4x4.com/forum/showthread.php?t=265669
k20 [OP]
  • Male Posts: 55
Re: springs
« Reply #2 on: Jul 08, 2005, 04:06:09 PM »
why do they use leaves from differant packs?heres a pic of a standard rear pack out of my truck,do the std trucks over there run the same pack?do you call the overload the small one on the bottom or the next one up that has the bracket that wraps around the rest of the pack?
MiniSimp
  • Male Posts: 5,120
Re: springs
« Reply #3 on: Jul 08, 2005, 04:35:05 PM »
Remove the bottom 2 leafs from that pack, add 3 more leafs.
You need to add more leafs because the thinner rear leaf is not strong enough to hold the front of the truck up.
If you want you can also add 1/2 a leaf to the top of the pack towards the front for an "Anti-wrap" leaf.
k20 [OP]
  • Male Posts: 55
Re: springs
« Reply #4 on: Jul 09, 2005, 01:30:04 AM »
what other 3 leaves do you recomend using?
k20 [OP]
  • Male Posts: 55
Re: springs
« Reply #5 on: Jul 10, 2005, 03:19:12 AM »
is any one using a double shackle set up on the rear?
4DEES
  • Turtle Points: 28
  • Male Posts: 1,403
  • Member since Jul '04
  • THROW SOME DEES ON THAT B1TCH!!
Re: springs
« Reply #6 on: Jul 10, 2005, 03:58:15 AM »
HYENA runs a chevy pack and he has a double shackle,might wanna ask him.  :thumbs:
***ROCK BRAWLERS~Southern Cali***
 www.rockbrawlers.com
'85 Toy, 42's and a body lift!
ROCK IT TILL THE WHEELS FALL OFF!!
MiniSimp
  • Male Posts: 5,120
Re: springs
« Reply #7 on: Jul 10, 2005, 11:27:55 AM »
I'm using the 3 that had the most arc.
k20 [OP]
  • Male Posts: 55
Re: springs
« Reply #8 on: Jul 11, 2005, 04:37:14 AM »
thanks for that!
Last post Jan 24, 2004, 04:03:14 PM
by Thumper
Last post Jul 03, 2004, 07:01:34 AM
by lowgeared
Last post Nov 11, 2004, 03:25:00 PM
by kneedownnate
Last post Apr 13, 2005, 07:37:39 AM
by TRDISMO
Last post Apr 07, 2006, 02:19:13 PM
by twerp
