Author Topic: R150 Shift Problem  (Read 2554 times)
Viru5
  • Turtle Points: -29
  • Member since Jun '05
R150 Shift Problem
« on: Jun 20, 2005, 04:09:55 AM »
Got a friend with an '87 turbo supra that won't shift into 1st or 2nd (R150 5-speed tranny).  What could possibly cause this, i.e., how hard would it be to fix, and if it needed a rebuild, can it be rebuilt with the normal gearing instead of the lower 1st gear?  I myself have an '82 Hilux 4WD, and I'e had good luck with Marlin in the past, and he seems to be the only one that does these rebuilds.
Thanks in advance for any help.
« Last Edit: Jun 20, 2005, 05:11:34 AM by Viru5 »
Panman
Re: R150 Shift Problem
« Reply #1 on: Jun 20, 2005, 08:00:18 AM »
You get very few tranny questions answered here.  My daughters 86 R151 had the same problem and it turned out to be the shifter fork was broke, rebuilding now.
UNBREAKABLE
  • Turtle Points: 372
  • Male Posts: 2,028
  • Member since Aug '04
  • Yeah, I guess you could say I'm a RockStar
« Reply #2 on: Jun 20, 2005, 08:09:55 PM »
I think that that tranny is a R154? :confused:
That's how I roll
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #3 on: Jun 21, 2005, 10:38:10 PM »
It is very common for the 1-2 fork to break due to the larger shift hub, and mainshaft retainer plate wear.
Unless the cause of the mainshaft movement and loose 5th gear is corrected, the fork will break again.
I recall the R154 having a 3.24 first gear:crossed: . This is the highest 1th gear made.
Other lower 1th gears are; 3.83 [R150, R150F, R151], 4.31 [R151F], and 5.15 [R452].
I am writing from home and do not have my R notes in front of me.
I sell a heavy duty retainer plate, and yes, I rebuilt the R154 trans.
Adam F
  • Member since Mar '04
« Reply #4 on: Jan 06, 2009, 12:43:37 PM »
Old thread, I know.  But I'm also having trouble shifting to and from 1st and 2nd.
How do I check the 1-2 fork?  Can it be seen through the top of the trans via the shifter plate?
Whats the fix?
Any pictures of the fork?
RN37DD
  • Male Posts: 742
  • Member since Apr '07
« Reply #5 on: Jan 06, 2009, 04:51:11 PM »
no you have to take the tranny apart to see the forks on a r150/r151. i had problems with my 4runner because a fork retainer bolt was loose. but I'd pull your shifter off first and check the condition of the shifter seat first. they go bad quick.
Last post Oct 18, 2006, 06:49:05 PM
by jr9162
Last post Nov 22, 2006, 08:44:16 AM
by eleet
Last post Dec 05, 2007, 05:24:17 AM
by wslytoy
Last post Oct 11, 2010, 10:33:10 AM
by Yotaowner
Last post Dec 14, 2014, 09:03:26 PM
by dntsdad
