Author Topic: choke break screw  (Read 1871 times)
oddball
  • Turtle Points: 1143
  • Male Posts: 952
  • Member since Jan '05
  • Weirdo
choke break screw
« on: Jun 15, 2005, 09:27:36 PM »
Ill be real impressed if somebody knows the answer to this one,,,,,,,,on my carburetor which happens to be an 85, there is a screw on the choke break cover that is painted yellow. I know you arent supposed to touch it but I tightened it all the way, now I need to know how many turns from tight is it suposed to be?
2008 Tacoma regular cab, 4.88s, ARBs, crawl box, manual shift FJ case
mr4x42u
  • Turtle Points: 700
  • Member since Sep '02
  • LOCKED AND LOADED
Re: choke break screw
« Reply #1 on: Jun 16, 2005, 04:18:05 AM »
are you talking about the high idle screw thats pre set from the factory?the one that controls how high your engine idles cold with the choke on?
oddball [OP]
  • Male Posts: 952
  • Weirdo
« Reply #2 on: Jun 16, 2005, 08:58:36 AM »
Possibly,,, there is a diaphragm with a rod inside and its actuated by the choke,,,the cover has 3 screws holding it on with a vacuum line coming out of it. The yellow painted screw is in the center, Im pretty sure it has something to do with how far the diaphragm moves
mr4x42u
  • LOCKED AND LOADED
« Reply #3 on: Jun 16, 2005, 09:16:18 AM »
can you post a pic,,i guess depending what carb is on it..The diphram is the choke pull off,,but the cover your talking about sounds like it is the heating element wich is adjustable rich or lean..
so what is your problem,,and what are you trying to do?is your idle too high?lopeing cold??
germ
  • Turtle Points: 349
  • Male Posts: 733
  • Member since Dec '04
  • Work sucks, I'm goin' wheelin
« Reply #4 on: Jun 16, 2005, 11:55:30 AM »
I would back it out as many turns as you tightened it.....Just kidding I have no idea :thpst: :pokinit: :roflsign:
* Regardless of what happens, someone will find a way to take it too seriously.
* 2% rule: Must be 2% smarter than what your working on.
* If you make something even a fool can use, only a fool will use it.
* I've been crapping in the woods longer than lil'buddy has been alive!
Ferg
  • Turtle Points: 416
  • Male Posts: 577
  • Member since May '03
  • That was EASY!!
« Reply #5 on: Jun 16, 2005, 05:01:28 PM »
My book shows that as the AAP, Auxilliary Acceleration Pump, but does not show a screw in the center. My bet would be that the screw is a travel limiter, limiting the amount of fuel delivered during operation.  It's supposed to improve drivability when the engine is cold.
Some idiots are too busy knowing it all, to ever learn anything...
Willy Mammoth
  • Male Posts: 4,252
« Reply #6 on: Jun 16, 2005, 05:58:34 PM »
Sounds like a vacuum pull off diaphragm. We could use a pic to be sure.
oddball [OP]
  • Male Posts: 952
  • Weirdo
« Reply #7 on: Jun 17, 2005, 08:00:05 AM »
Ill post pics tonight, its on the 85 carb and the 82 that I just bought. The FSM for 81, 82, 83 and 85 does not have a good diagram of it
oddball [OP]
  • Male Posts: 952
  • Weirdo
« Reply #8 on: Jun 18, 2005, 09:09:58 AM »
this is my 82 carb but its the same as the 85, oh and its the yellow painted screw
Last post Mar 22, 2005, 10:47:44 PM
by kneedownnate
Last post Jul 14, 2005, 04:10:44 PM
by teambeer1
Last post Mar 21, 2006, 12:11:24 PM
by 4WD22R
Last post May 22, 2006, 04:48:41 AM
by trax28to
Last post Apr 12, 2014, 04:58:58 AM
by jssgbsn
