Author Topic: PLEASE HELP!! Rear differential noise....  (Read 3345 times)
79-83earlyota
  • Turtle Points: 18
  • Male Posts: 181
  • Member since May '05
  • Earlyota
« on: Jun 08, 2005, 08:06:35 PM »
To let everyone know before I explain the problem, my Toyota has the original '80 rear axle with 5.29 gears and a Detroit Locker, and has always worked flawlessly until today. Anyway, I was driving home today, on the Interstate doing about 60 mph, nothing out of the ordinary....when my rear differential started to sound pretty bad. The noise is coming from the pinion up near the companion flange and rear drive shaft flange. Then, later, the pinion seal went out, because I've got 80W90 covering the entire back end. Don't be confused though, the noise was there long before the gear oil started dumping, so this noise is not a result of having a low fluid level in the diff.
The noise will NOT happen when I have my foot on the gas, so when there's torque on the pinion it sounds perfect, but the minute I let off the gas, put in the clutch, or am basically coasting or slowing down, it sounds like the whole 3rd member is gonna fall apart. I cannot get it to make the noise in reverse, whether on the gas or off of it. When full-on braking, for say, a sudden stoplight, the pinion is even more noisy and almost starts to ratchet or act like it's getting stuck. I can not only hear, but SEE the entire process in action, because I have no bed, and only a tube cage welded to the frame, so I can look out my rear cab window and down at the diff.
Doesn't this seem like a bad pinion oil seal and a worn pinion bearing to you guys??? I believe this to be true, because of the fact that it is noisy ONLY when off the gas or in neutral. I want some feedback and/or 2nd opinions. Also, I know there are two pinion bearings, the front bearing and the rear bearing (inside the carrier). Would I have to replace both??? If it does turn out to be the oil seal and bearings, I don't have any pullers, anybody who might be in Denver, Colorado want to help me out, or get PAID to do this project for me?? My time is SO limited, I don't even know when i'll be able to get to it. PLEASE HELP!
gnob
  • Turtle Points: 486
Re: PLEASE HELP!! Rear differential noise....
« Reply #1 on: Jun 08, 2005, 11:48:06 PM »
yep, sounds like bearings.
i had a similar problem in the past and bearings cured it.
hold this. . .
mr4x42u
  • Turtle Points: 700
  • Member since Sep '02
  • LOCKED AND LOADED
« Reply #2 on: Jun 09, 2005, 12:15:25 AM »
sounds like a loose pinion nut,,,letting the pinion walk in and out,,would explain the gear oil...could just be a pinion bearing let loose also..start by pulling the drive line off the rear yolk and see if the nut is tight..if not tight,,pull the diff,you have carnage..
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
« Reply #3 on: Jun 09, 2005, 02:22:33 AM »
Or your $500 paper weight detroit let go and it ratcheting uncontrolably.  Pull the driveline and check for loose parts.  Remember that wonderfull detroit has 1/4 turn of backlash built into it so dont be alarmed if it turns about that far before there is any tension against it.
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,052
  • Member since Dec '03
  • Crawlin with Marlin
« Reply #4 on: Jun 09, 2005, 07:13:00 AM »
I gave you a point to cheer you up!   :thumbs:
Auto problems are a bummer.  Hopefully you get rolling again soon.   :driving:
BUBBA
  • Turtle Points: 16
  • Male Posts: 1,138
  • Member since Mar '05
  • this sucks
« Reply #5 on: Jun 09, 2005, 09:05:49 AM »
It's also possible you have broken pinion teeth.I have had this happen before and the only time it would make a noise is when i let off the gas and was coasting.Whatever the problem is,sounds like it's time for a rebuild.
My budget beater
  • Momentum Man
  • Turtle Points: 759
  • Male Posts: 13,855
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #6 on: Jun 09, 2005, 05:28:40 PM »
Loose pinion nut/crush sleeve, when you are under power it lifts the pinion up when you let off the gas the pinion drops and rubs/drags on your locker housing. Get a new crush sleeve and pinion nut and it should fix the problem. Might as well do the bearing while your at it that constant movement will/may mess it up.
Last post Oct 08, 2006, 04:57:06 PM
by i_luv_my_truck
Last post Nov 13, 2009, 10:58:45 AM
by joey0712
Last post Nov 13, 2012, 12:16:44 PM
by Nimyad
Last post Mar 26, 2016, 09:46:22 AM
by Dingman.
Last post May 07, 2016, 08:41:00 PM
by Plainview
