cut out at 2000 rpm's can be a number of things,start with the timing, check fuel pump pressure, check mass air flow sensor, check tps, check injectors, run some injector cleaner just to be safe, check all vacume lines to see if they are in place,hope that helps
Started by horshu Engine
Started by FruitaCrawler Engine
Started by toynorcal General 4WD Discussion
Started by yotakid88 Engine
Started by motodude Toyota Pickup/4Runner Tech 1979-95
