Author Topic: Minitruck Axle in FJ40  (Read 7229 times)
Dooner
  • Turtle Points: 217
  • Male Posts: 769
  • Member since Feb '05
  • Invest in precious metal
« on: May 28, 2005, 11:22:49 AM »
Im in the process of getting parts together for a rebuild on my '72 327 FJ40. I picked up Minitruck front and rear axles for the project.
1) should I use the front end parts out of the Mini Axle in the FJ housing or just use the entire Mini front end in the FJ?
2) Would the Mini rear end survive under the weight of the FJ and the power of the V8? I got the Mini rear for its centered diff so  I
    could do a transfer case swap but could stay with FJ rear end and Transfer case if need be.
3) Would a Minitruck transfer case hold up under this rig with 35 to 36" tires with a 4 speed SM465?
"Project Land Cruzah" In Land Cruiser Section
71 FJ40 327/465/ 4.7 Mini T/c, Trussed, Armored Mini Axles w/ High Cross Over, Aussie Lockers & 30 spline Longs.  p/s 35's, SOA, , .  86 Burb D-60 14 bolt 350/400/205 37's.  02 F350 Tow Barge, Toyo 38's, Banks 5" Wicked wheel turbo, Edge Juice w/ Attitude, Blah Blah Blah
- Sales Employee -
freds40
  • Turtle Points: 293
  • Male Posts: 2,331
  • Member since Dec '02
Re: Minitruck Axle in FJ40
« Reply #1 on: May 28, 2005, 07:27:34 PM »
On the front axle, use the truck outers (knuckles to locking hubs) for the disc brakes. IIRC, the land cruiser R&P are larger. Also, you get the strength of the LC axle but you can beef even more with Longfields for the truck outers. The rear "should" hold up. I'm guessing you're not pushing too much power out of the motor so it should be alright. The t-case shouldn't have a problem either. The Toy case is a stout little unit (to a point) and you should be fine with your setup.
"between projects"
Dooner [OP]
  • Male Posts: 769
« Reply #2 on: Dec 04, 2005, 01:34:19 PM »
I ended up using Mini truck axles F & R on the Critter. For the front end Im gonna go wide with the IFS calipers, rotors etc. + some HD Birfs and inners along with some kind of locker... come on overtime!
Im wondering about the rear end though. would I be better off with a half ton Chevy axle vs building up an IFS wide axle with Ch Moly axles + Locker? Id like to find out before I invest in another rear end. If the Chevy is the way to go, which one is better the 10 bolt or the 12 bolt?
Any other ideas?
Thanks, Mike
- Sales Employee -
freds40
  • Male Posts: 2,331
« Reply #3 on: Dec 04, 2005, 04:04:23 PM »
Semi float 60, that's what my new Cruiser has. Ummm, beefy
"between projects"
Dooner [OP]
  • Male Posts: 769
« Reply #4 on: Dec 04, 2005, 06:51:26 PM »
Nice! but can I use one of these pups with a mini truck (centered) transfer case?
- Sales Employee -
freds40
  • Male Posts: 2,331
« Reply #5 on: Dec 04, 2005, 10:13:50 PM »
Oh yeah, definately. They come from the factory centered. This one was probably about $2500-$3000 when the guy had it built. Re-centered, E-Locker, 35 spline Mosers, disc brakes.
"between projects"
Dooner [OP]
  • Male Posts: 769
« Reply #6 on: Dec 04, 2005, 10:56:58 PM »
Man you scored! That thing looks dialed.
Hammerhead
  • Turtle Points: 100
  • Male Posts: 564
  • Member since Nov '04
  • Junkyard Dog
« Reply #7 on: Dec 10, 2005, 09:30:59 PM »
...would I be better off with a half ton Chevy axle vs building up an IFS wide axle with Ch Moly axles + Locker?
Any other ideas?
Thanks, Mike
Minis and cruisers have the same spline count in the sidegears.  That means you can use the Cruiser chunk with the mini outers.  Welding up the hybrid housing is a simple job with regular fabricating tools.
FYI the GM 10 & 12 bolt rears would be a down grade in strength...
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
Last post Oct 28, 2014, 10:39:42 AM
by ecrum428
Last post Feb 12, 2007, 07:17:38 PM
by toyota landman
Last post Nov 08, 2009, 11:59:24 PM
by mobil1syn
Last post Mar 04, 2010, 07:00:24 PM
by sweetmeat
Last post Jan 09, 2011, 04:13:05 PM
by Coastie
