Author Topic: Martack for stock diff?  (Read 3084 times)
Oreo
  • Member since Apr '03
« on: Jun 15, 2003, 09:12:36 AM »
Just got some Longfields and have a stock open v6 diff in my "85 front axle. I am not going to have a Detroit in my front axle for another month or two. When I insert the inner axle shafts all the way into the carrier(stock v6 diff) the oil seals are in the right spot. So do I even need to Martack? Also, when I do get the Detroit will it increase carrier depth and cause the need for a Martack?
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
Incapable Front Suspension
- Sales Employee -
freds40
  • Turtle Points: 293
  • Male Posts: 2,331
  • Member since Dec '02
Re: Martack for stock diff?
« Reply #1 on: Jun 20, 2003, 03:26:17 PM »
I have heard that if the shaft won't move in or out enough to go off of the seal surface, you don't need a tack or a clip. On some lockers and LS's, they don't have the cross pins inside like the stock ones do. The Martack is used on these diffs, because otherwise the shaft could slide in past the seal surface. I also have heard that the detroit has the cross shafts so you shouldn't need them in there either. My thoughts are if you can keep from tacking them, it makes it easier when you break something to just slip off the birf rather than have to grind it off.
"between projects"
mr4x42u
  • Turtle Points: 700
  • Member since Sep '02
  • LOCKED AND LOADED
Re:Martack for stock diff?
« Reply #2 on: Jul 15, 2003, 03:41:44 AM »
the martack is also for the ease of getting tha birf off with out having to beat the hell out of it on the trail so I think its a good idea..Here is a write up on it however I think there is also one on this web site as well.. :beerchug:
http://www.off-road.com/toyota/cheaptricks/clipweld/
  • Administrator
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #3 on: Jul 15, 2003, 11:54:28 AM »
You know the reason we stopped doing this is because people were not following our directions, and were placing the martac to far in, and one guy had an ARB and when he bolted down the spindle, it was tight but he kept going and I believe he broke part of the carrier or some internal piece on the ARB and demanded Marlin to replace his ARB. When we inspected his axle, the martac was like an inch to far in, you know something way the heck off and it was so obvious he didnt know what he was doing....
But after this Marlin pretty much stopped recommending this because to many people were not following his exact directions and making mistakes.
But it works great when done correctly ;)
mr4x42u
  • LOCKED AND LOADED
« Reply #4 on: Jul 16, 2003, 06:21:49 AM »
 :nonono:some people ruin it for everyone..
I love it just for the fact its sooo easy to change a birf. :biggthumpup:
Last post Mar 07, 2003, 04:42:46 AM
by rdkll
Last post May 15, 2005, 08:48:11 AM
by Makman
Last post May 19, 2005, 04:50:25 PM
by kyle_22r
Last post Aug 31, 2006, 04:34:15 PM
by kvn85
Last post Nov 30, 2006, 11:51:24 AM
by *FFC*
