1987 Suzuki Samurai Soft Top
1.6 16V 4cly engine
5 speed manual transmission.
Transfer case:
Rock Monster 6.4:1 transfer case gears and the "Mighty Kong" combination t-case mount / skid plate.
Front end:
5.12 geared Sidekick ring and pinion gears set up and installed in a Samurai housing
lockRite.
1 1/4" aluminum wheel spacers
Rear end:
5:12 geared Sidekick rear 3rd member with drilled flanges for the Samurai drive line
Hybrid axle housing
mini spool.
SJ410 Backing Plates
Grizzly Fab track Bar
Front and rear rock guards on the 3rd members
33x12.50 Mud terrians on 10” Rockcrawler steel rim.
Custom front bumper
Tow bar
6 Napa implement rock lights
Petroworks roof rack
Suspension:
Front YJ mounting kit with Missing Link
Rear YJ mounting kit with Missing Link
Stock YJ springs
Knuckle Over Steering
Urethane bushings with steel sleeves
extended brake lines
1 extended slip yoke in rear
2 one-inch driveline spacers for front
Front and rear lower shock mounts
1 pair front Ford upper shock towers
2 pair adjustable spring perches
4 Doetsch Tech 8000 prerunner shocks
Heavy duty axle u-bolts
1" body lift (to clear 16V motor)
Cobra CB
NEW carpet kit still in box
LOCATED IN SEASIDE OREGON
$5000 obo Trade for Built of semi built 4 runner
Located in Seaside Oregon
