Author Topic: L52??  (Read 877 times)
chevyLUVtoyota
  • Turtle Points: 60
  • Male Posts: 489
  • Member since Mar '05
L52??
« on: Apr 26, 2005, 08:55:32 AM »
hey is there a tranny that i can put in that is the same size as the L52 in my 83??
Jared
  • Turtle Points: 170
  • Member since Dec '03
  • Rolled baby.... IN front of my house....
Re: L52??
« Reply #1 on: Apr 26, 2005, 09:08:41 AM »
you can use just about any tranny from a 4wd but if you use a diff tranny with diff lengths you will need to relocate your shifter holes, drivelines and crossmember mounts....  if you want a tranny with the same length i think the l 43 4 speed and the l50 5 speed will work but why step down... the l52 is the best out of all of them... oh wait i forgot the L52 HD is the best but its $$$$$$$  but $$ well spent....
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: L52??
« Reply #2 on: Apr 26, 2005, 09:35:13 PM »
All '79 to '83 trans are 21.5" and the '83 L52 is the best of the early trans. [Jared was right again.]
'84 and newer trans are 25" long.
The L52H/D trans that I build would be your best bet.  :driving:
chevyLUVtoyota [OP]
  • Turtle Points: 60
  • Male Posts: 489
Re: L52??
« Reply #3 on: Apr 26, 2005, 11:10:08 PM »
haw much is sumthing like that??? my tranny is sloppy
derek
  • Turtle Points: -61
  • Male Posts: 600
  • slow truck=more time to nap
Re: L52??
« Reply #4 on: Apr 27, 2005, 06:34:32 AM »
