Author Topic: 1989 Runner  (Read 2937 times)
1Bad4Runner
  • Turtle Points: 45
  • Male Posts: 609
1989 Runner
« on: Apr 20, 2005, 06:29:58 AM »
I just bought a 1989 Toyota 4Runner and it has been sitting for a few months. The idle is kind of funny, right now it is idling at 500-600 rpm... What is a normal idling rpm?
also the idle is very up-and-down, When I have it is first gear while idling it feels like it wants to stall, but it is just the rough idle.
Oh, by the way, this is a 3.0L Fuel Injected! :smack:
89' 4Runner || Everythings Gone!! for now.
97' 4Runner, 2.7, Auto - Daily Driver
Pickup_foxrider
  • Male Posts: 55
  • PROJECT TOY UNDER WAY!!!
Re: 1989 Runner
« Reply #1 on: Apr 20, 2005, 01:30:46 PM »
Mine idles about the same. Mine whole truck shakes but that is from a bad engine mount. I need to replace. Hope that this helps.
89 Toyota 4Runner (stock)
91 Toyota Pickup
4" Susp Lift
3" Body Lift
35" MTR
DVD
10" Sub
More to come!!
I wheel with anything or anybody!!!
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Re: 1989 Runner
« Reply #2 on: Apr 20, 2005, 01:33:59 PM »
My 3.0 does that too, but after I changed the fuel filter it ran smoother.  before I did my engine swap, my truck idled at around 900 rpm.  I need to bump it back up on the new(er) motor, and see how it works there.  You said it had sat for a for months?  The engine I put in my truck was from an 884runner that was parted out, and the motor sat for a while.  It seems as if these 3.0s dont hold their running qwuality for very long when left unused :dunno:
              -Ronald Reagan
1Bad4Runner [OP]
  • Turtle Points: 45
  • Male Posts: 609
Re: 1989 Runner
« Reply #3 on: Apr 20, 2005, 02:00:12 PM »
I don't think its the motor mount.
Maybe I should check my fuel filter and see if it is dirty, also my throttle is sticking when I leave it sit for around an hour. I put oil on it but it doesn't help any.
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
Re: 1989 Runner
« Reply #4 on: Apr 20, 2005, 02:04:33 PM »
Ok, that is funny.  My throttle was sticking as well.  One good stomp and it came unstuck, but as soon as my engine cooled down, it stuck again.  Once I changed my fuel filter, it went away.  Try that, its an easy fix, and if its the same fiulter that has been sitting for a few months, it prolly needs it anyway.
              -Ronald Reagan
1Bad4Runner [OP]
  • Turtle Points: 45
  • Male Posts: 609
Re: 1989 Runner
« Reply #5 on: Apr 20, 2005, 04:38:05 PM »
Hah, this is great... I'm glad that you had all these problems (sort of) because this is helping me alot  :thumbs:
Thanks a lot BLACKDOG  :beerchug:
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
Re: 1989 Runner
« Reply #6 on: Apr 21, 2005, 12:08:17 PM »
:beerchug: no problem, hows it coming?
              -Ronald Reagan
1Bad4Runner [OP]
  • Turtle Points: 45
  • Male Posts: 609
Re: 1989 Runner
« Reply #7 on: Apr 21, 2005, 01:52:16 PM »
Bought a pump, couldn't get it in because one of the fittings wouldn't come off, so I have to try later again.
Huhwhye
  • Turtle Points: 24
  • Male Posts: 639
  • Member since Jan '03
  • Huhwhye, esq.
Re: 1989 Runner
« Reply #8 on: Apr 21, 2005, 03:39:22 PM »
I'm fixing this Chevy for a guy right now that does the same thing.  This is what I have done
Change or check the PCV and all vacuum hoses.
Cleaning the throttle body.  Use T-body cleaner or some Brake Cleaner if you already have it. Spray it into the TB to clean all the crap out.  There will be black and brown crud all over it if it's never been cleaned.  Then change the fuel filter and maybe run a bottle or 2 of Techron thru it.
Also check and make sure the cap, rotor, spark plugs and wires are in good shape.  They weren't
I also am running an AutoRX clean cycle with fresh oil and filter.  I also changed the air filter.
After I did all that, this Chevy with 160k miles on runs like new.  He hasn't picked the truck up yet, but I'm sure he'll be pleased.  I ran terrible before
'04 Taco DC 4x4
1Bad4Runner [OP]
  • Turtle Points: 45
  • Male Posts: 609
Re: 1989 Runner
« Reply #9 on: Apr 21, 2005, 05:42:32 PM »
Thanks a lot Huhwhye, I will check all the vaccum hoses and check my air filter to see if it is dirty.
1Bad4Runner [OP]
  • Turtle Points: 45
  • Male Posts: 609
Re: 1989 Runner
« Reply #10 on: Apr 24, 2005, 12:06:01 PM »
I just replaced all of the vaccum hoses, except 2.. also I took the throttle body and the intake manifold off today and clean it all up. There was quite a layer of black crap all throughout the throttle body and intake, so I clean all of that out with carb cleaner.
It runs a lot better, the throttle doesn't stick anymore, but the idle is still up and down a lot... any ideas?  :help:
Last post May 14, 2004, 11:14:31 AM
by soma56
Last post Mar 01, 2005, 04:26:30 PM
by timo992001
Last post Aug 31, 2006, 10:17:10 AM
by Blk Widow
Last post Jun 06, 2010, 11:26:03 PM
by superkaliguy
Last post May 19, 2016, 12:26:50 PM
by Plainview
