Timing? Ignition or cam. If the cam jumped a tooth starting would be hard, two teeth and it won't start at all. I'd say check your distributor trigger, but if you have spark that may not be an issue.There is (carby I presume) a fuel cut solenoid on the carb to prevent run-on, but it doesn't affect the main circuits.Exhaust could be completely blocled. Even then you'd get a pop at least.
How big of a spark are you seeing at the spark plug?Gnarls.
It's kinda of a purple spark. Nothing huge, but it does spark.
I just got back in from verifying TDC and the timing seems fine. The rotor in the distributor was pointing at #1 wire on the cap. The crank shaft was at 0. I sprayed some brake clean (didn't have a skinny funnel to get gas) in each plug hole and it still didn't even try to start. I asked my wife to crank it while I twisted the distributor and if I twist in all the way to the opposite side that it was initially running at, it sputtered but didn't start. I may just take it to a shop soon. If any of you guys have instagram mine is japanesecoyote and you can see on my stories what I've been up to with it.
So I have to ask, no insult intended, are the ignition wires right? It'll be interesting to see what the issue is. Typically something simple.
No insult taken haha. I assume they are right as I haven't changed their configuration since it ran last. I took photos of how it was hooked up before replacing it. Though now, I question myself.
You'd be surpeised how many people do just that. I learned my lesson in my VW days. I once drove to the store and back home on one cylinder! Buddy was pranking me and swapped the coil wire with a plug wire. For some reason I couldn't see it. I just thought I'd be pulling the engine that night.Ah, the good 'ol days!
Here's a video of what I've got so far. https://www.youtube.com/watch?v=3r7Pc4R-HsgI'm sure I changed my fuel filter last year.
So it "tried" to fire and start. It could be an ignition or ignition timing issue?Even with the vacuum advance is not working, I believe it should start.I assume you have checked and verified the firing order and the spark plug wires to each spark plug.Gnarls.
Yes, I checked each plug in the wire for spark. Firing order should be correct. The cap is marked so it's pretty easy.I ended up getting a new distributor, I'll switch it out and see how that goes.
So, watcing the video. Engine tries to start when timing is retarded from where you started. looks like enough timing adjustment. The vacuum advance should be two separate circuits. If I remember correctly one diaphragm advanced (farthest out) and one retarded (inner diaphragm), so putting them on rhe same circuit would cancel them out.My concern is the noise I hear in the video. Could be nothing, but sounds like a knock. Could be something rattlin' around when you crank the engine. Could be something bad. Need more input.
Started by toyotaboy General 4WD Discussion
Started by traveler727 Engine
Started by mtntoy Engine
