Author Topic: Hydro Assist:box and pump mods  (Read 337619 times)
  • Shoutbox Moderator
  • Male Posts: 7,110
  • Member since Nov '05
Re: Hydro Assist:box and pump mods
« Reply #240 on: Jul 08, 2007, 07:36:37 PM »
Well i ended up using JB weld to fill the crevice and i smoothed it with a die grinder. Put the Correct 0-ring on and it dosent leak at all now! I was really excited about that. Ran the rubicon saturday and it worked great. Wow jb weld does wonders. :)
WOW! i mean really wow..that is amazing....  :suprised:
Yota4life
  • Turtle Points: -128
  • Male Posts: 1,461
« Reply #241 on: Jul 08, 2007, 08:08:23 PM »
I know that it probley leaked from that but it was also because i was running the wrong 0-ring before. I used jb weld on my t-case to fill cracks and it still dosent leak. haha
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
  • Member since May '05
« Reply #242 on: Jul 08, 2007, 08:23:27 PM »
Very happy to hear :beer:
My build up. Getting linked
DieselD
  • Male Posts: 409
« Reply #243 on: Jul 27, 2007, 10:45:25 PM »
awesome write up, made tapping my box a breeze. took about 3hours from start to finish which includes running around looking for drill bit that was worth a damn. Ive never been inside a toy box either so it was new.
either way it was easy. I have yet to get it on the truck and pumping fluid but hopefully all is well.
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #244 on: Aug 17, 2007, 12:19:36 AM »
Freds40,
Have you ever had any issues with the fitting on top of the box not being able to thread in very much since the tap can't go that deep. I have done a couple of boxes and wish the fitting went in deeper than 3 threads. I am working on another one now and I am going to use a second tap after running the first one that bottoms out. My second tap will be from the same maufacturer, but I am going to shave off 1/4" from the tap. Hopefully this will allow me to use the wider part of the tap and be able to get the fitting to screw in more than 3 threads. If I get 4 or five I will be very happy. Especially if it does not leak.
- Sales Employee -
freds40 [OP]
  • Turtle Points: 293
  • Male Posts: 2,331
  • Member since Dec '02
« Reply #245 on: Aug 17, 2007, 06:23:09 PM »
I know it can happen. When I do mine I run the drill bit to the very bottom of the vein. Then run the tap in as tight as possible. I can usually get 4-5 threads to grab. When I have done Sag boxes, I have used a second ground tap to get it in deeper.
"between projects"
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #246 on: Aug 17, 2007, 10:02:35 PM »
Good advise.. Thank you :beer:
Vortec_Cruiser
  • Turtle Points: -1
  • Male Posts: 58
  • Member since Apr '03
  • 1977 FJ40
« Reply #247 on: Sep 29, 2007, 11:17:07 AM »
Use your regular tap, and then use a bottoming tap, which doesn't have a taper to it.  This will give you full-depth threads.  ;)
Ed Gilbert - TLCA #5659, So. Cal. TLCA,
1977(reg. as 1962) FJ40 w/5.7L Vortec
Formula 4 Toy F006 (Build in-progress)
ryno1
« Reply #248 on: Nov 06, 2007, 08:58:19 PM »
Fred, is the 4cyl pump the same as the V6 pump?  I have the V6 and was wondering if the process for drilling the restrictor is the same.
JZ
  • Turtle Points: -2
  • Male Posts: 87
  • Member since Nov '06
    • Heres the Yota
« Reply #249 on: Nov 21, 2007, 10:51:58 PM »
same here fred I got the v6 also and there isn't many options of a pump.
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #250 on: Nov 22, 2007, 12:27:56 PM »
The v6 pump I worked on had two small holes in the restrictor instead of one from the factory. In trying to knock out the restrictor to figure out how to drill it, I ended up puching a hole between the two holes accidently. So I ended up with one large hole. For some reason the restrictor would not come out by lightly tapping it out. It ended up working out just fine.
Good luck
Yota4life
  • Male Posts: 1,461
« Reply #251 on: Nov 22, 2007, 07:58:12 PM »
Good luck
Same happened here. I tried punching it out and it broke out. Been running it for a long time with no problems. Works great
chadchad/ rocksnot
  • Member since Jan '07
« Reply #252 on: Jan 08, 2008, 08:33:10 AM »
thanks for helping save money bra
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
« Reply #253 on: Feb 13, 2008, 06:34:18 PM »
If you didn't want to run assist could you just drill the restricter on the pump to get stronger power steering?
  • Male Posts: 7,110
« Reply #254 on: Feb 14, 2008, 12:29:42 PM »
Good luck
I used a nail that I found on the garage floor to poke mine out...works great so far :yupyup:
- Sales Employee -
freds40 [OP]
  • Male Posts: 2,331
« Reply #255 on: Feb 23, 2008, 05:29:21 PM »
Updated with Rick's info.  :thumbs:
"between projects"
BigBs84
  • Turtle Points: 3
  • Male Posts: 349
  • Member since Aug '06
« Reply #256 on: May 21, 2008, 12:43:27 PM »
Hey man I did that and you had to get the rpm's up for it to turn it sucked so I put a stock one back in and it works fine
Build it wright-wind it tight
   High-N-Tight offroad
http://board.marlincrawler.com/index.php?topic=45027.0 My truggy build
Bazzi
  • Turtle Points: 97
  • Male Posts: 1,095
  • Member since May '04
  • From Reykjavik Iceland...
    • R&T
« Reply #257 on: May 21, 2008, 02:18:20 PM »
I can´t find a post from rick... where is the new scoop   :hammer: (modified) sorry guy´s I am a dumb  :moon:
the info is at page 1.
« Last Edit: May 21, 2008, 02:26:07 PM by Bazzi »
- Sales Employee -
freds40 [OP]
  • Male Posts: 2,331
« Reply #258 on: May 22, 2008, 02:29:29 PM »
Bottom of page 1
"between projects"
sixtninecat
  • Member since May '08
« Reply #259 on: May 24, 2008, 06:04:44 PM »
The 9-4410-06 Cylinder is out of stock indefinitely at Surplus Center.  What are some other places to get cylinders online???
Joe
- Sales Employee -
freds40 [OP]
  • Male Posts: 2,331
« Reply #260 on: May 24, 2008, 09:06:21 PM »
That sucks. I bought one just a month or so back. Check out Northern Tool. They should have a 6" stroke 1.5" cylinder.
"between projects"
  • Male Posts: 7,110
« Reply #261 on: May 26, 2008, 12:22:41 PM »
Just FYI, Ballistic Fab just came out with 1.25" clamps for your tie rod mount
http://www.ballisticfabrication.com/OD-Tube-Clamp_p_21-1474.html
Doof
  • Turtle Points: 41
  • Male Posts: 3,205
  • Member since Apr '07
  • establised summer of 89
« Reply #262 on: Jul 26, 2008, 06:56:23 PM »
bump so i dont have to search again
  • Male Posts: 7,110
« Reply #263 on: Jul 27, 2008, 06:02:19 AM »
This thread is a sticky! :doh:
Doof
  • Turtle Points: 41
  • Male Posts: 3,205
« Reply #264 on: Jul 27, 2008, 05:39:04 PM »
cool
:thumbs:
dont really care
kiyul4130
  • Brown Star Award
  • Turtle Points: 279
  • Male Posts: 3,265
  • Member since Jul '05
  • Turdburgalin since 1985
« Reply #265 on: Aug 29, 2008, 08:45:29 PM »
i tapped my box yesterday. it was quite easier than i thought it seemed to be. i still dont have all my steering together to see how it works yet. i will post once its completed.
-kiyul-
ECV 7-11
KYOTA FOREVER
yota-tota
  • Turtle Points: 17
  • Male Posts: 232
  • Crawling over Marlin
« Reply #266 on: Sep 08, 2008, 03:47:05 PM »
anyone drill and tap the box without taking it apart? seems like it would work if you just took your time drilling it out....like keep blowing the chips away and put some grease on the end of the drill bit and tap to grab the chips. Also use a s strong magnet by your drill bit to grab the chips as well.
I'm just worried about not getting it back together correctly that's all and a few small chips can't make that big of a deal.
91 toy truggy on h2 injection, hacked n chopped n locked n SAS'd rolling 36" IROKS........doubler comming soon
4XFlyin
  • Turtle Points: -8
  • Male Posts: 541
« Reply #267 on: Sep 08, 2008, 08:50:21 PM »
I have done 3 of them. I can tell you that there is no way of doing it with out having chips stuck inside. Go ahead and do it if you want. Please post up after at least 1000 miles and let us know how it turned out.
  • Male Posts: 7,110
« Reply #268 on: Sep 09, 2008, 05:50:41 AM »
yes they are a big deal.    dont try to take a shortcut on your steering..just do it the right way man
yota-tota
  • Turtle Points: 17
  • Male Posts: 232
« Reply #269 on: Sep 09, 2008, 04:44:15 PM »
hahaha sooo i took it apart today after work and it ya it was a joke BUT on re-assembly i hooked that teflon ring and split SO i just tried to put it back together until i can order the seal (which i hope you can) but i couldn't get the teeth on the input thingy to be in the right phase to mesh with the teeth on the slector shaft....when i put the slector shaft back in it would twist the other piece side ways. After 4 tries and the seal breaking i had enough and left it until tomorrow.
There has to be an easier way to make sure that input shaft is in the right phase because if it moves and turns on you your deffently going to tear that seal.
Last post Jan 29, 2006, 08:49:05 PM
by KYOTA
Last post Aug 18, 2006, 12:22:14 PM
by 4RnrRick
Last post Mar 10, 2010, 08:54:02 AM
by Rocksnail
Last post Feb 26, 2016, 09:20:14 PM
by T2crawlfun
by supermoto917
