Author Topic: R series 2nd gear differences.  (Read 1187 times)
onwheels
  • Turtle Points: 9
  • Member since Feb '20
« on: Jan 12, 2023, 04:17:16 PM »
I'm in the process of rebuilding an R151F and have discovered the 2nd gear is trashed. It has quite a few chips on the teeth which I was considering grinding/smoothing out, though once I started, I realised it was more damaged than I thought.
From what I can see, there are 2 different 2nd gear types and according to Partsouq & my local Toyota Genuine Parts, the gear I need is no longer available. So after comparing the diagrams for my R151F and the later models (though still pre-1KD usage), it looks like the only difference is the gear & the matching synchro.
Of course this is an extra couple hundred dollars I wasn't expecting on this project, so am hoping someone has experience with this and can confirm before I place the order?
Cheers.
onwheels [OP]
  • Turtle Points: 9
Re: R series 2nd gear differences.
« Reply #1 on: Jan 19, 2023, 07:02:24 PM »
Just to update this in case anyone comes across this issue in the future; I've ordered the newer style 2nd Gear and matching synchro.
Part numbers are as follows;
3303360050 - 2nd Gear
3303735030 - Synchro
Will update once the parts come in as to whether they fit or not.
Prismo
  • Turtle Points: 8529
  • Member since Oct '03
  • Living in the green house
« Reply #2 on: Jan 19, 2023, 07:14:27 PM »
I will be following your results as I have the same transmission and have wondered where to find parts if mine fail.
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
« Reply #3 on: Jan 19, 2023, 09:41:01 PM »
Just to add to this thread in case anyone interested. I rebuilt my R151F and hated the 1st and 2nd gear ratios after swapping in a 3.4. I swapped in the gears from a R150F (3.0 V6 version) Direct swap.
88 Pickup SAS'd, 3.4 V6, R151F Hybrid, Dual Ultimate, Triple sticks, 35's, 5.29's, HP front, V6 rear, Aussies, 63" Chevs, Anti Wrap Bar, Warn 8274 on Home Built Bumper
4WU linked 86 Xtra Cab build in progress
onwheels [OP]
  • Turtle Points: 9
« Reply #4 on: Jan 20, 2023, 03:59:42 PM »
Most parts are readily available, though from what I can find, I've got an older gearbox with the nut on the countershaft and this 2nd gear arrangement which is no longer in production.
onwheels [OP]
  • Turtle Points: 9
« Reply #5 on: Jan 20, 2023, 04:00:34 PM »
Good to know. This is going behind a 1KZ so gear ratios are as intended.
onwheels [OP]
  • Turtle Points: 9
« Reply #6 on: Jan 29, 2023, 04:39:46 PM »
Ok, for anyone following along, the parts have come in. The newer style 2nd gear measures up to be the same as my original older style (apart from the synchro area), so thats a good start. The synchro is a completely different design (3 piece) and the inner diameter is smaller to suit the newer 2nd gear. Unfortunately, the spring/key arrangement is also different. I should have realised this when looking at the diagrams and pictures, though most of this I'm doing after work, late at night, so I blame my brain for being half asleep.
So I now need to order the synchro on the other side of the hub and the appropriate springs and keys.
In the above image, the original spring/key arrangement is circled in red. The new style is in green, and the new synchro I need to order is shown in orange. Hopefully this is all I need to get this thing back together (and working).
So far, 2nd gear and the matching synchro has cost me an extra ~$180aud and I received it within a week of ordering. I went to my local Toyota parts dealer and they quoted me over $400+aud just for the 2nd gear, with a 4-5 week wait from Japan. I'm not even going to bother checking pricing with them this time, as I can see a few local companies selling the synchro for $130aud and the keys for $8aud EACH. I'm about to place an order for 3 keys, 3 springs & 1 synchro, with delivery for $64.80aud.
Part numbers as follows;
3336535060 - Synchro keys (x3 req'd)
3336735080 - Synchro (x1 req'd)
9050108158 - Springs (x3 req'd)
2manytoys
  • Male Posts: 583
« Reply #7 on: Feb 04, 2023, 09:36:07 PM »
Thanks for the update. Dead end threads suck.
onwheels [OP]
  • Turtle Points: 9
« Reply #8 on: Feb 07, 2023, 04:30:32 PM »
No worries. Hopefully it can save someone a few headaches if they ever come across this issue.
I received the new synchro, springs & keys and got set up and ready to re-assemble. Unfortunately I realised the synchro hub needs to be changed as well.
The new 3 piece synchro on the 2nd gear side (33367 in the above diagram) has a different design, with tabs in the center which lock into the face of the synchro hub.
I didn't pick this up, and when checking part numbers, the image shown on the website shows the opposite side, which looks the same as the original part I have. Also, I did not realise there is a recess for the springs to mount in. Luckily I noticed this before I pressed the hub all the way on.
So the new part required is "Hub transmission clutch No. 1" Part number 33361-71010.
You can barely see the recess for the springs in the above image. This is what led me to believe this is the same as the part I have.
Here is a better look at it.
And here is the recessed face required for the synchro to locate in.
4Ruinned
  • Member since Oct '11
« Reply #9 on: Feb 08, 2023, 06:44:48 PM »
I wonder if the 2nd gear from a AX15 works with the older style syncho/hub in a R151F.
That gear has 33 teeth, same as the one in the R151 and the AX15 is pretty much an R series transmission.
onwheels [OP]
  • Turtle Points: 9
« Reply #10 on: Feb 09, 2023, 02:27:06 PM »
Looking at it I'd say you're right. I wish I had of thought about that when I was looking for a replacement  :hammerhead: looks like they're easy to find too.
Ah well I'm this far in now may as well keep going!
Last post Jan 10, 2007, 02:53:25 AM
by Toy zuki
Last post Jan 10, 2008, 06:34:27 PM
by BUDDERS
Last post Dec 21, 2009, 12:46:36 PM
by sabenson82
Last post Dec 21, 2009, 01:55:49 PM
by toyodaaddict
Last post Feb 08, 2011, 06:39:22 PM
by Sparkplug
