Author Topic: no heat  (Read 6360 times)
sumedumbkid
  • Member since Feb '03
  • I love Marlin Crawler!
no heat
« on: Apr 03, 2003, 07:51:01 PM »
ok so my heater only works on 1 speed and i dont know wich one all the whiers have power like ther suposed to and i hav 4 motors and thay all do the same thing so i hooked up a toggel switch to see if i could get it to go faster same thing  slow and no heat normly i woulden care but im going to play in the snow this weekend and my wife wants heat so aney thoughts
ERIC
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
1981 toyta 33" muds 33" custom lift  rear buggy springs and 56' chevys w56 5speed
  • Turtle Points: 679
  • Don't blame me, I didn't vote for this crap.
Re: no heat
« Reply #1 on: Apr 03, 2003, 09:50:18 PM »
check out the thread below this one called heater?
it will probobly answer your Q's
cruzila
  • Go go cruzila!
  • Hawk
  • Turtle Points: 41
  • Male Posts: 3,848
  • MC20/21 Toybox #002 2.28 = 154:1
    • MTA
Re: no heat
« Reply #2 on: Apr 04, 2003, 02:05:18 AM »
There is a rehostat/condenser/capacitor :screwy: thingy on the heater. I can not remember what it is called. Mine went out and the fan had one speed. The dealer can look it up easy enough and it was not too expensive if I remember correctly.
Scott
sumedumbkid [OP]
Re: no heat
« Reply #3 on: Apr 04, 2003, 07:37:01 AM »
thanks for the help i replaced the reostat deal this morning and i have no change
krawlr
  • Member since Oct '02
  • ManBearPig Rowrrr!
    • Krawlr website
Re: no heat
« Reply #4 on: Apr 04, 2003, 11:10:10 AM »
If the blower resistor fails you get hi fan or nothing at all. Hi speed on the switch bypasses the resistor but some setups have a fuse built into the resistor assembly.
So your saying the fan only runs in the low speed switch position? Or does it run slow in all switch positions?
If it's only running in low position and you've replaced the resistor, I would say it's the switch.
If it runs slow in all positions, I would look for a bad connection like a bad ground or a connector in the system.
27-AT, some other adapter, flipped D300, twin sticks on cables.
[shamelessplug] www.krawlr.com [/shamelessplug]
Don
sumedumbkid [OP]
Re: no heat
« Reply #5 on: Apr 04, 2003, 12:01:00 PM »
ok the fan only gose slow no matter where the switch is or what switch i use i have 3 comp-leet heater systems and thay all do the same 3 switches 3 motors all the same way only thing the same is the box there in can i have a short in the heater box
krawlr
    • Krawlr website
Re: no heat
« Reply #6 on: Apr 04, 2003, 01:48:32 PM »
Well without the truck in front of me I don't know what else to tell you except recheck connections. :dunno:
Is there anymore history on this, was it working and then quit, or has it been like this from the time you got it?
Don
sumedumbkid [OP]
Re: no heat
« Reply #7 on: Apr 05, 2003, 06:13:42 AM »
i fixed it the main supply wrier to the cab wasent flowing but 8 volts and like 4 amps to the whole cab i replace it and now it works just fine it dident have enuff juice to power the motor aney faster the power wire had been hacked to for the stereo that was in it when i got it  it wasnet getting full current flow
eric
sumedumbkid [OP]
Re: no heat
« Reply #8 on: Apr 07, 2003, 02:45:04 PM »
TIP!!!:  :ladysman: hey cutie y don't u warm her up in the snow???? :heyhey:
(AKA not eric)
wife
Last post Aug 29, 2004, 08:57:00 PM
by toyman2
Last post Aug 14, 2009, 02:57:22 PM
by oregonwheeler
Last post May 14, 2010, 07:13:03 AM
by DFWFO
Last post May 18, 2010, 10:14:09 PM
by snaps10
Last post Dec 14, 2010, 09:37:33 AM
by Dr.Maxwe001
