Author Topic: MC08 Coupler Question  (Read 185 times)
Dr Phat
  • Turtle Points: 223
  • Member since Oct '09
« on: Jan 12, 2021, 12:13:14 PM »
So I get the low speed gear slips onto the MC08 coupler and also gets a detent ball and thrust washer. However, does the snap ring, retainer ring, pressure plate, and “synchro” also get installed with the low speed gear or does that need to be removed from the gear prior to being installed on the coupler? I might have the nomenclature wrong or not understanding what the parts purposes are for but the Marlin installation instruction don’t really address and it and Trail Gear shows it being installed without it. Just not sure what the correct set up is! I’m referring to what’s left of the low speed gear once it’s pulled off the main shaft.  :thumbs:
OVRAROK
  • Turtle Points: 23882
  • Male Posts: 2,938
  • Member since Dec '10
Dr Phat [OP]
Re: MC08 Coupler Question
« Reply #2 on: Jan 13, 2021, 07:45:49 AM »
Yes that’s the instructions where it dosent really address the question.
Apparently it’s part of the “quiet run” gear assembly. It is not required but is also not necessary to disassemble prior to installation. I’m guessing it adds a little bit of preload to keep the gears meshed in a quiet pattern for them run together. If anyone else has info I’d appreciate it. Case is fully assembled and ready to drop in my rig!
Last post Apr 27, 2011, 08:32:20 PM
by Bobby Hunter
Last post Nov 05, 2004, 07:47:06 PM
by 914Runner
Last post Jan 16, 2005, 10:31:13 PM
by Roktoys84
Last post Dec 18, 2009, 02:45:51 PM
by troyman
Last post Aug 21, 2011, 02:14:50 PM
by T.U.F.F.
