I got to looking and it has a lot of seeping oil too.
Checked my timing and it’s at 8 degrees, but when I disconnect the vacuum advance it doesn’t change. I can feel the vacuum on the inner line so I know I have a bad vacuum advance on my distributor. Anyone know where I can get one? Toyota doesn’t make them anymore
May try calling napa auto..I think that's where I got the one on my 84 from..
That's strange.. I just searched in distributor parts section..asked me a few question..BAM...
What about junk yards?
No old carb Toyota’s in junk yards here. What’s the name of the guy in Denver? Is it yota Jim?
Take the cap off the distributor, attach a vacuum line to both nipples of the vacuum advance, suck and see what happens.............
On the distributor....As I remember... on 85 22R I had timing advance issue.I believe I took the disty apart and cleaned and lubed it and it worked fine.Just a thought from the late 90's!! Gnarls.
When you rev up the truck with vacuum advance connected does the timing change? That's how I've always tested vacuum advance units
Gnarls, do you mean to take apart the distributor itself or are you talking about disassembling the vacuum advance diaphragm. I actually called yoda jim and yotayard, but no answer. I was able to leave a msg for yotayard, but yoda Jim's voice mail system is full. I will call back later. I then reached out to LCE only to learn that they will not be getting the vacuum advance back in stock and they don't have any distributors except the DUI which I don't want. Their old manufacturer went out of business. So I am guessing if we run a 22R we are all basically screwed. I don't see how the most well known and popular 4 cylinder ever produced has such poor parts supply
It’s just me so I can’t check. I could check with a friend this weekend
Do you use the hand pump? What exactly should I expect to see? The rotor move?
Also, I found this thread on YotaTech. This post https://www.yotatech.com/forums/f116/22r-vaccum-advance-not-working-what-will-do-108688/#post50587927 suggests the truck should be drivable without vacuum advance. I have no idea if the poster knew anything or not
Started by toybuilt « 1 2 » Rig Gallery
Started by 79-83earlyota Toyota Pickup/4Runner Tech 1979-95
Started by 8D3TOY Engine
Started by mlatrella Toyota Pickup/4Runner Tech 1979-95
Started by E120ER Engine
