What needs to be done to run rears up front. The front bushing in the rear leafs has a smaller ID that the factory front leafs.
When I SAS my 4runner. I built a set of RUF. IIRC I used a 79 main leaf. The spring pin was offset the most on these particular year springs. I think i ended up with a 7 leave pack. I can check later on. Which after they where done pushed my front axle forward. Fit my 35s nicely. Rode like a cadillac. I've never had the common issue of rubbing on the firewall. I have since purchased SKYS 3F springs.. RUFs are a great economical solution in my opinion. Also let's you dial in height and softness. I think I followed Roger at 4crawler. https://www.4crawler.com/4x4/4R_suspension-III.shtml#Front
I've no access to the early packs, so will be 88-96 rears mixed and matched, polished and tapered, painted and greased.I need to order some leaf clips from rough country as well.
Started by dat82toy General 4WD Discussion
Started by KYOTA Rig Gallery
Started by spc mike Parts Wanted
Started by NorthBayCrawler Newbie Questions
Started by Overlandoutcast Suspension
