... I started having an oil leak at the front of the head. Pieces of the gasket have came apart where it’s leaking....
When doing the head gasket..theres alot of stuff that you remove..I would get this...https://22reperformance.com/22re-gaskets-and-seals/head-gasket-set
No machine done. Did not overheat. Loosing water threw the exhaust ports. So I decided to change the gasket.
Sorry to mislead. The 1st time done it was because of loosing water threw the exhaust. I replaced the head gasket and it did okay for a while. Now, this time it’s the oil leak in the front.No flat check was done. I’ll check the timing chain cover first.
Started by Krylon Parts For Sale
Started by BLACKDOG 1989-1995: How-To Guides
Started by The_Blue_Coyote Engine
Started by BLACKDOG « 1 2 » General 4WD Discussion
Started by seafarinman Parts Wanted
