Yes, the body's are interchangeable between the 2 and 4 wheel drives models. However, it likely isn't worth it, as more than likely you will be cutting them for tire clearance anyways.
If your Std. cab 4x4 is still relatively clean, I would build the 2wd independently, leaving the std. cab as it is, and sell it, you will likely be money ahead.
