Author Topic: 4.30 gears interchangeable with 4.37 gears?  (Read 1272 times)
Mojavewanderer
  • Member since Sep '20
« on: Sep 15, 2020, 07:57:44 AM »
Hey everyone, I have a 1980 Toyota 4wd pickup with the stock 1980 only 4.37 differential gears. I blew up the rear end, and need to get it fixed, but 4.37 gears are pretty difficult to find. I was told that 4.30 gears were close enough to work without causing any problems. Is there any truth to that, or am I being fed a line of bs? Thanks!
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,052
  • Member since Dec '03
  • Crawlin with Marlin
Re: 4.30 gears interchangeable with 4.37 gears?
« Reply #1 on: Sep 15, 2020, 08:09:38 AM »
I think you can find sources to support a difference of 1-2% is workable. I think where I’ve seen different gear ratios on rigs in magazines they generally had the lower gear ratio in the front so that the front end was pulling rather than the back end pushing. I’d guess that you’d be ok in the dirt where there’s some give, but don’t know how it might change things on the rocks.
mudmaster
  • Turtle Points: 3687
  • Male Posts: 2,847
  • Member since Feb '05
« Reply #2 on: Sep 15, 2020, 08:58:13 AM »
It's close enough to not be an issue.
Time to go wheelin!
liveoak
  • Turtle Points: 102
  • Male Posts: 155
  • Member since Mar '08
« Reply #3 on: Sep 15, 2020, 01:28:17 PM »
I would bite the bullet and put 4:56 in both(as opposed to 4.10) if you have bigger than stock tires or find a pair of used takeout thirds. I guess it depends on how your 4-speed feels now with the 4.37s but I would imagine 4.56 would give a bit of improvement all around.
Gnarly4X
  • Online Gold Turtle Award
  • Turtle Points: 5134
  • Male Posts: 4,225
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
« Reply #4 on: Sep 16, 2020, 05:05:57 AM »
Call 1-866-631-0196  and ask them.
Gnarls.
Mojavewanderer [OP]
« Reply #5 on: Sep 16, 2020, 08:24:44 AM »
Thanks for the replies! Ideally I would definitely re-gear both differentials, but that’s not in the budget right now. Based on your responses, and some other research, I think I’m going to go with the 4.30s. The new 4.30 diff will be in the rear, and 80% of the time it will be in 2 wheel drive, so it should be ok. The truck is on 31 inch tires, right now, and the biggest tire I would put on it would be a 33. The 4 speed does alright right now, it’s an old Toyota, so it’s slow, but I can get it up to 70 on the freeway if I push it.
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #6 on: Sep 16, 2020, 11:24:12 AM »
With less than a 2% difference between the two, you shouldn't notice the difference on the trail.
Last post Apr 23, 2005, 06:47:19 PM
by 79coyotefrg
Last post Apr 07, 2006, 07:07:03 PM
by 79coyotefrg
Last post Jan 07, 2007, 01:18:00 AM
by alwayzbroken
Last post Nov 12, 2007, 09:34:41 PM
by germ
Last post Apr 16, 2021, 01:05:55 PM
by bpwilliams
