Author Topic: 1980 Toyota 4x4 - re-gearing needed for 33” tires?  (Read 2806 times)
bcarroll76
  • Member since Aug '20
« on: Aug 03, 2020, 04:43:36 PM »
Howdy, just bought my son a 1980 Toyota 4x4., from what I can tell it has 4.37 gearing.  Should this truck have different gearing to accommodate the 33” tires?  Will take it hunting sometimes, but typical driving to school and back, no crawling or mudding.
Reason I ask is that the previous owner chewed up the diff and I was concerned if it was from the bigger tires.
Thanks all!
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,052
  • Member since Dec '03
  • Crawlin with Marlin
I ran 4.10 gears with 33s on my ‘85 truck and found it unacceptable so went to 4.88s. I don’t think damage should be expected in your case, just a lack of “go” power.
RUGER
  • Turtle Points: 16415
  • Male Posts: 1,017
  • I love Marlin Crawler!
when i got my 83 it had 4.10 and i did lift and tires first. i had to really milk the clutch with the 35s and yes power was an issue. eventually came gearing and decided on 5.29s and it was a ton better.
haveing big tires on stock ratio shouldnt hurt the gears, just wearing clutch faster.
fer yer setup 4.88 is about right.
jack up yer truck and spin a tire and count how many times it takes fer yer driveline to make a revolution. this will give you a rough estimate of what ratio you have. do it fer both axles. i bought a truck and found that it had different ratios front and back.
RUGER :usa: :beer: :usa:
:usa: GOD BLESS AMERICA :usa:
"the hag" 83 toy with 5" all-pro lift, marlin crawler dual case #1011 and marlin hy-steer, 35s, 5.29's, exo cage, yada, yada, yada. she's back in black.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
USN SEABEE 2008-2012 :usa:
run with THE PACK 4wdc of los osos
NRA life member
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
4.88 would be a good upgrade. But I have an 81 with 4.37, 4 speed, and 33s. It does just fine. Not the fastest on acceleration, but it will do interstate speed with no problem.
01 double cab hunting truck
06 tacoma street truck
bcarroll76 [OP]
Thanks all, @Ruger,  I will for sure check to ensure front/back match.
I think I will stick to the 4.37 since it is just my son and he DOESNT need to be in a hurry anyhow ;)
I am in CO and can’t find a 4.37 3rd member locally to save my life!  Any of you have ideas on places to look for getting one?  We are a bit new to the Import 4x4 family.
Thanks lot guys!
bcarroll76 [OP]
Update - bit the bullet and replaced front and rear with 4.11 gearing.  Runs great
Thanks everyone!
RUGER
  • Male Posts: 1,017
glad its working out fer you.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
NRA life member
liveoak
  • Turtle Points: 102
  • Male Posts: 155
  • Member since Mar '08
you went from 4.37 to 4.11 gearing? that is the opposite of the advice you received. seems like you made it worse.
should have at least gone 4.56
« Last Edit: Sep 03, 2020, 10:00:06 AM by liveoak »
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Thanks everyone!
I realize you got what you could find on a budget but its not too hard to find 4.37's I ran my truck for about 12 years with 4.37's and 32's
NOW I have 5.29's and 35's and my speedo is perfect
blackdiamond
  • Male Posts: 5,052
Wait...but my speedo is perfect with 4.88's and 35's.  You must have full height 35's because I think the math with 4.88's lines up with 34 inch tires.
Gnarly4X
  • Turtle Points: 5134
  • Male Posts: 4,218
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
If your engine is a 1980 20R, the peak torque is a low 2400 RPMs, with peak HP at 4800.
If the transmission is an L43 4 speed, 4th gear is 1:1.
Typically the choice of gearing is based on where your peak torque is and what RPMs your want it to be in the RPM range for the speed of your pickup.
In other words, with 4.11 R&P and 33” tires, in 4th gear your RPMs will be 2511 at 60 MPH.  At 75 MPH your RPM will be 3139 in 4th gear.
In my 1986 XtraCab, 22RE with a W56 5 speed, 30” tires, 4.56 R&P, at 80 MPH my RPM is about 3200 in 5th gear, which is just about in the middle of my peak torque curve and a comfortable cruise RPM.
Gnarls.
« Last Edit: Sep 13, 2020, 04:36:16 AM by Gnarly4X »
  • Momentum Man
  • Turtle Points: 759
  • Male Posts: 13,855
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Ran 4.37's on my 80 with no issues but the motor was 22r/20 swap and the trans was swapped to a 5 speed. Don't know how it acts with the 4 speed and a stock 20r but if you swap gears go with 4.88's if you go with 5.29's you may have to increase the size of the notch in the housing in order to get the ring gear to fit through which if cut too big will leak.
Gnarly4X
  • Male Posts: 4,218
What size tires?
Gnarls.
  • Momentum Man
  • Lego Enforcement
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
Your speedo could be wrong.  With 33 BFG AT's w/4.88's in my '90 the speedo is spot on with gps, regardless of speed, w/35 BFG MT's and 5.29' on my '91, the speedo reads about 5mph high throughout the range, both are on 15x10's, w/5spds.
Last post Jul 16, 2006, 11:42:51 PM
by DTB
Last post Jul 30, 2007, 08:02:17 AM
by wflaw45
Last post Feb 05, 2010, 03:15:59 PM
by BoG-ToY
Last post Jul 31, 2011, 01:09:39 PM
by ERICLICEA
Last post Jan 05, 2016, 05:25:18 PM
by Yotaoverland
