86 4R 22RE 4x4The engine periodically surges under load and intermittently having a hard time starting it. Battery and starter are fine just may take a couple minutes of trying to turn it over. Have an engine code "6".No engine revolution sensor (Ne) signal to ECU- Ne being over 1000 RPM in spite of no Ne signal to ECU- Defective Igniter circuit- Defective Igniter- Defective distributor- Defective ECUCode 6 point to the coil and ignitor.Another symptom is an erratic fatory tachometer, as the tach. signal comes from the ignitor circuit.Should I start with a new distributor then coil, igniter?Sent from my SM-N976U using Tapatalk
dont know. maybe we didnt give him the info he wanted to hear. i thought it was a fuel issue could be electrical to. hahaRUGER
Where's the "damn_cajun" Gnarls.
