So I'm install a Dana 300, AW4 from a Cherokee into my Hendrix X chassis buggy with a 22RE engine. I understand I can use the bell housing from an A340 trans? Any idea where to find one? I also need the spacer that goes between the flex plate and crank from the Toyota right? I can use the flex plate as well as torque converter from the Jeep trans though right? This is the first time I've swapped from Manual to Auto. I took the clutch and slave cylinder out, but the flywheel is still there. It had a W56 trans in it.
