Author Topic: Corroded hub found during rebuild- would you run it?  (Read 2193 times)
IVrunner
  • Turtle Points: 23
  • Male Posts: 352
  • Member since Oct '06
  • Santa Barbara, CA
« on: Apr 18, 2020, 11:05:08 PM »
I grabbed an 84 solid axle from my dad but it lived it’s life in the salt belt so during my SAS and axle rebuild I found a pretty bad rust corrosion on the hub.  I don’t want to go thru all the effort if it doesn’t seal right.  Would you run it, find some used ones in better condition, or buy new replacements?  I see there are OEM options and upgraded versions.
It’s going on my 87 4runner which is my DD.
https://photos.app.goo.gl/BTwC3G6DFDwKDZ9q7
Josh
« Last Edit: Apr 18, 2020, 11:24:58 PM by IVrunner »
~Josh
-87 4Runner SR5 - SAS, 4.88's, 33 KM2s, Lockright front, elocker rear, frenched hangers, TG in front, 63’s in rear (DD)
-2010 4runner Trail (wife DD)
-2000 4runner 4WD manual Highlander -SOLD:(
-1986 Toyota pickup SAS on 35s -SOLD
-1985 4runner (first car) -SOLD
Gnarly4X
  • Turtle Points: 5134
  • Male Posts: 4,226
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
Hey Josh,
Well those are way too pitted.  On a daily driver or trail rig I would NOT use those.  :shake:
That hub houses your wheel bearings... you would NOT want one of those fracturing and causing a possible wheel to lock up or worse break off at 70 MPH!  :yikes:
Gnarls.  :thumbs:
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
I'd clean them up some more and then decide.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OVRAROK
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
Find some ifs hubs...chances are you already have a set if your vehicle was running..they will make front axle same width as rear..without spacers.. you'll need these..
https://frontrangeoffroadfab.com/tacoma-and-4runner-brake-mounting-kit/
When rebuilding solid axle..flip the knuckles from left to right as per instruction on kit..you'll have to source some rotors and calipers from late model tacoma or 4runner...I found my rotors/calipers on a 3rd gen forum..alot of those guys are doing a big brake upgrade..the end result will give you slip off rotors..
« Last Edit: Apr 19, 2020, 05:35:42 AM by OVRAROK »
Gnarly4X
  • Male Posts: 4,226
In order to "clean" those, you'd have to machine them in a lathe.
Ain't worth the time or cost....  https://autoplicity.com/cart
Just my opinion - it may be worthless.
Gnarls.
Gnarly4X
  • Male Posts: 4,226
IVrunner [OP]
  • Turtle Points: 23
  • Male Posts: 352
  • Santa Barbara, CA
Thanks for the responses.  That’s what I figured.  What you are seeing is cleaned up the best I could.  You should have seen them when I started...
 I do have good IFS hubs and was looking at going that route but many of the builds I saw looked a little sketchy.  I’ll check out the front range kit.
~Josh
IVrunner [OP]
  • Turtle Points: 23
  • Male Posts: 352
  • Santa Barbara, CA
~Josh
T-Revv
  • Turtle Points: 722
  • Male Posts: 278
  • Member since Apr '17
  • Crawlin at work, Crawlin on the trails. best life.
I agree with Ovarock. Run IFS hubs.  1 1/2" wider than solid axle, so it eliminates the need of a spacer, and everything else stays exactly the same. Direct bolt on.  You don't need the Tacoma brake kit to run the IFS hubs, but it is a good upgrade.  -Trevor
"I dunno I just woke up from a lil nap, it's a lil dark but you guys silly? I'm still gonna send it."
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
For removing rust, it is hard to beat Metal Rescue for passive rust removal, just have to have something big enough to soak the part in.
Draggingdiff
  • Member since Apr '21
I would run them, spray some paint on those things and go!
Last post Jan 07, 2008, 04:43:42 PM
by lucky7
Last post Jan 16, 2009, 07:17:50 AM
by gmack192
Last post Nov 22, 2014, 08:49:09 AM
by Erick561
Last post Aug 08, 2017, 05:20:25 PM
by 58rennur4
Last post Jun 20, 2019, 08:38:09 PM
by mrspib
