Author Topic: Transfer Case Break in & fluid??  (Read 3442 times)
idahank
  • Turtle Points: 219
  • Member since Nov '13
« on: Mar 18, 2020, 10:00:31 PM »
Hay you all I was just wondering what is the break in procedure and what fluid you guys recommended I use in my freshly rebuilt Marlin Transfer Case
1980 body,1983 running gear with 4.11 Detroit Truetracs front and rear, New Marlin Transmission & T-Case with 4.7 gears, 30x9.5 R15 Cooper Discoverer STT LT, custom front & rear bumpers.
RUGER
  • Turtle Points: 16574
  • Male Posts: 1,017
  • I love Marlin Crawler!
Re: Transfer Case Break in & fluid??
« Reply #1 on: Mar 19, 2020, 09:31:03 AM »
id use 80-90 but not sure what t-case yer running.
id run it fer a bit and change the fluid and good to go.
RUGER :usa: :beer: :usa:
:usa: GOD BLESS AMERICA :usa:
"the hag" 83 toy with 5" all-pro lift, marlin crawler dual case #1011 and marlin hy-steer, 35s, 5.29's, exo cage, yada, yada, yada. she's back in black.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
USN SEABEE 2008-2012 :usa:
run with THE PACK 4wdc of los osos
NRA life member
idahank [OP]
« Reply #2 on: Mar 21, 2020, 09:14:58 AM »
Just heard back from Marlin and they suggest to break in with conventional 75w90 for the first 1000 miles then they recommend using Redline 75w90 fluid. So I thought someone out there might want to know.
Thanks
calux
  • Turtle Points: 93
  • Member since Aug '20
« Reply #3 on: Aug 14, 2020, 11:54:17 AM »
i know this is an old thread but how is the redline oil working out, about to install duals and am debating that vs  Neo Synthetics 80-90
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,052
  • Member since Dec '03
  • Crawlin with Marlin
« Reply #4 on: Aug 14, 2020, 08:05:01 PM »
You’ll never notice a difference with expensive gear oil in your transfer case. You will feel a difference with MT-90 in your manual transmission.
Gnarly4X
  • Online Gold Turtle Award
  • Turtle Points: 5134
  • Male Posts: 4,225
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
« Reply #5 on: Aug 15, 2020, 01:41:00 AM »
I have run everything from 20w-50 Castrol motor oil, Redline MTL, to Mobil 1 Synthetic.  The difference in shifting is very noticeable between conventional 75-90 and Redline or Mobil 1. If I lived in a very cold climate, I’d be running ALL synthetics, they flow easier at cold temps. I’m running Mobil 1 now and shifts up and down are smoother than with the conventional 75-90 gear oil.  I live in the Phoenix area and Redline and Mobil 1 did lower the temperatures on the tranny shifter and the t-case shifter when grabbed with my hand at the base of the shifters, especially during our 100+ summer months.
https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-1-syn-gear-lube-ls-75w-90/
https://www.redlineoil.com/mtl-75w80-gl-4-gear-oil
By the way, in my rebuilt 5-speed, the tranny shop installed Toyota Factory synchros, and the shifts were a little notchy for about 1,000 miles. I switched from conventional 75-90 to Redline MTL (recommended by Redline Tech) and it really made the shifts much smoother.
Personally, I would NOT drain and refresh my tranny or t-case oil after a "break-in" period.
Gnarls.
« Last Edit: Aug 15, 2020, 01:57:51 AM by Gnarly4X »
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
« Reply #6 on: Aug 15, 2020, 03:56:29 AM »
I always ran Redline MT 90 because I was told there was no sulfur inside.  Meaning if water got inside it would not turn to sulfuric acid and harm the brass syncros.  Not sure if this is true.  it worked well for me though.
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
Gnarly4X
  • Male Posts: 4,225
« Reply #7 on: Aug 15, 2020, 05:33:41 AM »
According to Redline's site, only difference between MTL and MT-90 is viscosity.
https://www.redlineoil.com/Content/files/tech/Manual_Transmission_Tech_6.20_.pdf
Gnarls.
Wainiha
  • Male Posts: 1,170
« Reply #8 on: Aug 15, 2020, 08:41:48 AM »
I thought the "to slippery" came from the sulfur and that is what posed a possible problem to the the syncros as in GL-5 lubes.  Maybe I'm remembering incorrectly.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
YotaRick
  • Male Posts: 18
  • Member since Jul '21
  • Low and slow
« Reply #9 on: Jul 28, 2021, 09:29:50 PM »
Any new gears are going to have a lot of wear right off the bat. Do a oils change after new gears within the first 50-100 miles then usually maintenance after that
Wainiha
  • Male Posts: 1,170
« Reply #10 on: Jul 29, 2021, 07:40:18 PM »
MT-90 back of bottle says something about GL-5 being to slippery for brass syncros.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #11 on: Jul 29, 2021, 08:47:25 PM »
I believe orginally that to achieve a GL-5 rating,  a sulfur compound was added to the oil.
This sulfur compound would attack the brass/bronze synchro rings.
They may be able to achieve the GL-5 rating without the sulfur compound now.     So you won't have any problems with the synchro rings anymore.       Check the label,   find the MSDS sheet and see if there's sulfur in the oil.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
OVRAROK
  • Online Silver Turtle Award
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
« Reply #12 on: Jul 30, 2021, 04:44:55 AM »
I've torn down quite a few transfer cases..ive never seen brass, or synchros..  :dunno:
blackdiamond
  • Male Posts: 5,052
« Reply #13 on: Aug 01, 2021, 05:02:55 PM »
Of concern to tranny's only.
OVRAROK
  • Male Posts: 3,506
« Reply #14 on: Aug 01, 2021, 05:08:41 PM »
I didn't see transmission in the topic
blackdiamond
  • Male Posts: 5,052
« Reply #15 on: Aug 03, 2021, 05:34:32 PM »
I was intending to pile on to your observation that t-cases don’t have syncros. The discussion seemed to follow the tranny outline when the key factors don’t apply to t-cases.
Last post Nov 11, 2007, 09:00:16 PM
by Volcom
Last post May 10, 2011, 12:36:24 AM
by DeMented Toys
Last post Mar 13, 2020, 09:02:47 AM
by Bambino840
Last post Mar 24, 2020, 03:08:20 AM
by Gnarly4X
Last post Jul 27, 2023, 10:23:51 PM
by bigdaddy2021
