Author Topic: 22R/E rocker arms  (Read 2922 times)
mountain,man1
  • Turtle Points: 287
  • Male Posts: 78
  • Member since Jan '19
22R/E rocker arms
« on: Feb 05, 2020, 12:11:00 PM »
About a year ago the 22R/E in my 4Runner started a terrible rocker arm knock i pulled the vale cove to adjust the lash and it didn't help well maybe a lil any who i was gonna do a full motor rebuild now that i have the money something came up go figure so im gonna just change my rocker arms i just need advice on this i feel it can be done without removing the head but whould like input from smarter folks than i
88 TurdRunner 22RE W56B 31x10.5R15 no lift rust assisted weight reduction 100% trail damage
gnob
  • Turtle Points: 486
Re: 22R/E rocker arms
« Reply #1 on: Feb 05, 2020, 02:41:00 PM »
Not happening. Head bolts have to come out.
hold this. . .
Slabzilla
  • Turtle Points: 1355
  • Male Posts: 539
  • Member since Dec '13
« Reply #2 on: Feb 05, 2020, 06:36:41 PM »
Check for a bad cam chain guide before you get too far into changing the rockers as the slapping chain will sometimes mimic rocker noise.  Those plastic guides are problematic.  Front cover must come off to replace, but looking down from the cam gear and moving the guide lightly back and forth against the cam chain, any movement, replacement time.  Get Metal replacements.   :twocents:
  • Turtle Points: 5143
  • Male Posts: 4,210
  • Member since Jun '16
  • 4-wheeling vicariously.
« Reply #3 on: Feb 06, 2020, 02:10:30 AM »
Hi mountain,man1.....
You started posting here January last year.
You have asked a lot of questions and said what you are going to do to your 4Runner.
I'm just curious, what have you done to your 4Runner since January of 2019? :dunno:
Gnarls. :inthedark:
« Last Edit: Feb 07, 2020, 03:03:51 AM by Gnarly4X »
mountain,man1 [OP]
  • Male Posts: 78
« Reply #4 on: Feb 07, 2020, 07:11:24 AM »
I redid the top end 4 years ago But was under a deadline from the state of Colorado to get emissions and VIN check so I cut some corners. I know it's the rocker arms because when I did everything I put all new timing chain sprockets guides the work
mountain,man1 [OP]
  • Male Posts: 78
« Reply #5 on: Feb 07, 2020, 07:15:10 AM »
I moved it around a little bit. She still runs. She just don't sound happy. I did some wiring that needs to be done. Ive been working on the crappy crx trying to keep it going.
Gnarls. :inthedark:
mountain,man1 [OP]
  • Male Posts: 78
« Reply #6 on: Feb 07, 2020, 07:17:13 AM »
So the head has to come off. I have less than 20,000 miles on the timing chain kit Can it be reused?
gnob
« Reply #7 on: Feb 07, 2020, 09:07:36 AM »
Yes timing kit can be reused.
hold this. . .
  • Male Posts: 4,210
« Reply #8 on: Feb 07, 2020, 06:23:43 PM »
So you are driving that vehicle less than 5,000 per year, or 13 miles a day.
How many times in the less than 20,000 miles did you check and adjust the valve lash?
When you “redid the top end”, what did you do?  What parts, other than the timing chain kit, were replaced?
The top end typically means the head/valves, camshaft, and rocker rack.
What corners did you cut?
How many miles was on the engine when you redid the top end 4 years ago.
The rocker rack with camshaft can be swapped without removing the head.
Exactly why do you feel confident the “terrible rocker arm knock” is the rockers?
mountain,man1 [OP]
  • Male Posts: 78
« Reply #9 on: Feb 07, 2020, 10:11:04 PM »
I drive a company truck everyday so i don't put much miles on my own vehicles. The odometer read 237,000 when i had the head planed and resurfaced i put in a new timing kit (cover,chain,guides,tensioner,sprockets,water & oil pumps) and all new gaskets and seals for the whole motor the odometer currently reads 254,796
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
« Reply #10 on: Feb 08, 2020, 12:13:05 AM »
Are you sure you haven't wiped out a cam lobe?
It's possible to reassemble the rocker shafts wrong and not get enough oil up top...………………..
  • Male Posts: 4,210
« Reply #11 on: Feb 08, 2020, 08:22:33 AM »
Hey mountain,man1….
Trying to analyze a noise over the internet is like sniffing flowers through your butt.  :inthedark:
I’m asking questions to try to figure out where the “terrible rocker arm knock” is coming from.  Based upon the limited information I’ve read so far, I would be pulling a Wild A$$ Guess out of my butt. There is a HUGE range of conditions a high mileage 22RE can be in.  And many definitions of a “rebuild”.  :dunno:
I’ll let someone else with more experience than I have, or a crystal ball, comment.  :thumbs:
Good luck.  :beerchug:
Gnarls.  :spin:
mountain,man1 [OP]
  • Male Posts: 78
« Reply #12 on: Feb 13, 2020, 08:02:03 PM »
I hadn't thought of that
sirdeuce
  • Turtle Points: 1138
  • Male Posts: 534
  • Member since Sep '06
  • One shot, one kill.
« Reply #13 on: Mar 17, 2020, 10:48:44 AM »
Rocker bores worn oval, causes a "swinging" motion to the rocker making it impossible to get them adjusted properly. All it takes is a few moments of oil starvation or foreign material in the oil, like metal shavings or sludge to block the oil port. Yep, head comes off. Prepare yourswlf to replace the cam and rockers. Be sure to mikke the rocker shafts as well, they can wear enought to cause problems with new rockers.
Since you're there, replace the valve seals as well.
Last post Mar 14, 2006, 04:20:25 PM
by toymech
Last post Jun 10, 2006, 06:44:04 PM
by 79coyotefrg
Last post May 20, 2007, 09:15:37 PM
by nate650
Last post Oct 17, 2007, 03:33:03 PM
by BUDDERS
Last post May 04, 2020, 12:02:11 PM
by Rusty Bob
