Shocks for Rock Crawling
Started by trigrate, January 27, 2020, 05:17:48 AM
trigrate
What is the best brand of shock absorbers for rock crawling?
zebracrawler
Depends on what kind of ride quality you're looking for the bilstein 5100 is usually the best option for most people. I have noticed they are a little stiff if you have a truck and running them in the rear.
sas 85 2wd dual cases locked rear 35s
http://board.marlincrawler.com/index.php?topic=81775.0
mudmaster
Rancho RS 9000 XL. The Bilsteins were too soft for me.
Time to go wheelin!
calux
bilstein 5125s are a good choice
blackdiamond
Quote from: mudmaster on March 16, 2020, 10:09:14 AM
Concur. I may have had the wrong application of the 5100 as I cannot imagine anyone being happy with them for crawling. I bottomed them out in Moab constantly dropping off ledges. With the Ranchos that are physically nearly identical in length it rarely happens.
Gnarly4X
Over my 20+ years of wheeling, I ran Rancho, KYB, Bilstein, Monroe, and Pro Comp.  My consideration was based on my Toy pickups being both week-end warriors and daily drivers. I found that Ranchos failed and leaked sooner than they should, but had nice features like adjustable stiffness knob.  Too stiff on the highway was not desirable, so I tried to find a compromise for highway and trail. Since 95% of my wheeling was slow rockcrawling stiffness on the trails was not a big deal, it was the extension and compression lengths.  Optimum articulation was most desired. KYBs tended to get stiffer after awhile, Bilsteins seemed to go softer, Monroe had minimum options, so ended up running mostly Rancho and I tried every one of their models, ending up with 9000s with the adjusting knob somewhere in the middle.  Now there are way more options for shocks.
Gnarls. :blah:
blackdiamond
Quote from: Gnarly4X on August 16, 2020, 04:59:28 AM
Gnarls. :blah:
I run 9000s maxed out all the time. It works great with my Alcans.
trigrate
Sorry for the late response, guys. I forgot my password. I would like to thank everyone for the feedback. I went ahead and had Bilstein Shocks installed on my crawler.
blackdiamond
Quote from: trigrate on October 15, 2020, 08:13:48 AM
I hope you have the positive experience that so many seem to have. If you find them to be inadequate, the Rancho 9000xl has treated me well and resolved my issues with bottoming out my suspicion/shocks constantly while rock crawling in Moab.
trigrate
Will keep that in mind. Thank you!
mudmaster
I had the same experience as BD and switched to the Ranchos.
Time to go wheelin!
