Just scored a set of 38.5x12.5x15 TSL SX’s. Would you run 8 or 10” wide rims? My plan is to run steel so I can weld bead locks on later.Thanks
With a 12.5 width in tire...I would run 15x8...
I would do steel. not enough thread engagement
Wow... I've never heard of a wheel falling off because of lack of thread engagement? Gnarls.
When I worked at the tire shop, 20 years ago, we would see this happen alot. Especially with the Tacos. The rule of thumb was, you needed a minimum of 1/2" thread engagement to be fairly safe. Alot of this was due to the aluminum was alot thicker there. I don't know now, but if you remember Toyota had Aluminum wheels with shouldered lugnuts on the 3 gen pickups.
I can understand why lack of threads on lug studs or lug bolts might be an issue for keeping the wheels on, but I would think an issue of known failures like that would be a DOT report and corrected. Wheels, like tires, have a D.O.T. spec.
... The lack of threads issue is something the buyer of the wheels has to address, or for the independent shop themselves to address with their customers.
Started by Huhwhye Chit Chat Camp
Started by DTB « 1 2 » Chit Chat Camp
Started by 85 toy crawler Toyota Pickup/4Runner Tech 1979-95
Started by gmack192 « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by IVrunner Axle/Differential/Steering
