Author Topic: Formula Four Toyota #004 Rebuild  (Read 7112 times)
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Member since Sep '04
  • Colorado Rocks!
    • http://www.rockfrogs.org
« on: Dec 23, 2019, 05:58:12 AM »
Got the opportunity to purchase a four seater Formula Toyota chassis from a good friend of mine (ColoradoToy91).
https://www.pirate4x4.com/forum/toyota-formula-toy-forum/1030496-co-formula4-build.html
He took his engine, transmission, t-case, and axles from this F-Toy and is in the process of moving it into a Rock Lizard chassis.
I've been wheeling a 1984 Toyota 4Runner for the last 15 years.  Started the build in 2004.  Typical 1st gen 4Runner build with Toyota axles.  I've been wheeling with buddies with buggies the last 5-6 years and being full bodied has been tough.  Especially tough on drivetrain parts.  Had my fair share of broken R&P's and twisted t-case outputs.
I haven't babied this 4Runner at all.  Its been wheeled everywhere in Colorado, Moab UT, South Dakota, and the Hammers.
Decided to sell the 4Runner to a good friend of mine.  Part of the deal was I kept the axles and t-cases.  Those will be transplanted into the F-Toy.
Untitled by VolcomCO
001 by VolcomCO
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Volcom [OP]
  • Male Posts: 2,418
  • Colorado Rocks!
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Volcom [OP]
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Formula Four Toyota #004 Rebuild
« Reply #2 on: Dec 23, 2019, 05:59:17 AM »
Picked up the F-Toy chassis this summer
Going to suck building a buggy in a small 2 car garage with too much stuff in it already
This what it looked like right before he tore it down
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Volcom [OP]
  • Male Posts: 2,418
  • Colorado Rocks!
« Reply #3 on: Dec 23, 2019, 05:59:47 AM »
The 4Runner ran before I pulled the engine but it ran poorly.  Tons of white smoke out of the tail pipe.  Figured it had a blown HG.  Pulled the engine apart and got the heads off it.  HG didn't seem to have any signs of a HG failure.  Decided to have the heads pressure tested and they were both cracked internally.
Picked up another 3.4 from a 99 Tacoma with 180K on it.  This motor had a manual 5 speed behind it.
Looked good inside.  Got a new timing belt, water pump, blah blah blah
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Volcom [OP]
  • Male Posts: 2,418
  • Colorado Rocks!
« Reply #4 on: Dec 23, 2019, 06:00:18 AM »
Had to pull the t-cases apart to get the stock 21 spline input in the front reduction block out.  Going behind an auto, it has to be upgraded to 23 spline.
Before the t-case surgery
21 vs 23 input by VolcomCO
Little size comparison
After
With the auto to gear driven case adapter
Stand alone 3.4 swap wiring harness that I bought
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Volcom [OP]
  • Male Posts: 2,418
  • Colorado Rocks!
« Reply #5 on: Dec 23, 2019, 06:10:51 AM »
Prepping for motor mounts.  Thanks for the help guys!!
Finally getting the engine into the buggy!!
Joe built some factory style motor mounts for his project and couldn't end up using them.  They worked perfectly for my F-Toy
Engine is in!  Pushed back as far as I could.
Got the t-cases mounted to the transmission and figuring out how to flat belly this thing.
It's tucked up above the bottom of the frame rails.  Only thing sticking down is the drain plug.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
bordain
  • Member since Jan '20
« Reply #6 on: Mar 02, 2020, 11:37:11 PM »
Everything looks awesome!
DutchVDub
  • Turtle Points: 137
  • Member since Sep '20
« Reply #7 on: Sep 23, 2020, 09:53:52 AM »
Project looks awesome.  I think I either bought my SD Dana 60 off of you or from the guy that bought your orange 4Runner.
Volcom [OP]
  • Male Posts: 2,418
  • Colorado Rocks!
« Reply #8 on: Aug 05, 2021, 08:38:04 AM »
You bought them from the other Aaron, my buddy that I sold my 4Runner to
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Last post Jan 15, 2004, 02:15:31 PM
by zags
Last post Jun 18, 2007, 11:08:59 PM
by welder2000
Last post Feb 13, 2012, 08:28:57 PM
by hansi530
Last post Apr 23, 2010, 05:29:16 PM
by broke40
Last post Jun 16, 2020, 07:42:01 AM
by Volcom
