Does anybody make a bolt on crank sensor set for the 22RE?
I'm looking at possibilities for my next build. The 36-1 wheel is available from many sources, but the sensor bracket is a bit more elusive. I have 2 more builds I want to do, a 7AGE (hybrid 7A block and 4AGE head) and a 2.6l 20R head on 22R block. Sensing crank and cam position allows a more precise tuning capability than the stock sensors allow. Better computer capabilities. More things to play with!
Let's just think at the amount of accuracy the 36 - 1 tooth wheel on the crank gives over the 4 + 1 the stock sensors give. With 36 timing events measured per crank revolution as opposed to 2 plus the TDC indicator pulse the stock distributor gives allows such a wider tuning capability. If the plans are to run with sequential injection and a COP ignition a position signal every 10 degrees of crank travel works MUCH better than every 180 degrees.
Started by Rebeltilldeath3 Engine
Started by havik Parts Wanted
Started by Glen1978 Parts For Sale
Started by Yota87Truck Toyota Pickup/4Runner Tech 1979-95
Started by Sparkplug Parts Wanted
