Author Topic: 1985 22re afm or mar sensor orientation  (Read 1320 times)
337junk
  • Turtle Points: 117
  • Member since Apr '19
« on: Oct 29, 2019, 09:49:05 PM »
So I am  getting rid of stock air box and doing a custom set up on the passenger side of my 85 4runner. My question is can I rotate the afm or mas 90 degrees with no issues. Has anyone done this with success? Thanks
Gnarly4X
  • Turtle Points: 5134
  • Male Posts: 4,252
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
Re: 1985 22re afm or mar sensor orientation
« Reply #1 on: Oct 30, 2019, 02:06:52 AM »
Why are you "getting rid of the stock air box"?  :headscratch:
What is "a custom set up"?  ???
Which 90 degrees?.... vertical or horizontal?  :dunno:
Since the AFM on that engines measures air temperature and air volume, and is a critical sensor/data input to the ECU (as well as a fuel pump shut off), I'm curious what your "custom set up" will look like? :inthedark:
Gnarls.  :gap:
gnob
  • Turtle Points: 486
« Reply #2 on: Oct 30, 2019, 05:09:34 AM »
Afm needs to be mounted in the same orientation as stock.  Otherwise the flapper door is fighting gravity and can potentially not work properly.
hold this. . .
sirdeuce
  • Turtle Points: 1293
  • Male Posts: 537
  • Member since Sep '06
  • One shot, one kill.
« Reply #3 on: Oct 30, 2019, 08:38:06 AM »
Gnob is mostly right. The weight of the flapper door would only affect the low flow characteristics of the flapper door's operation, like idle and off idle where the airflow is minimal. As to orientation..... With the flapper door orientated topwise your A/F mix will tend to richen as the weight of the flapper will be 'falling' helping the air to open it. Bottom orientation will lean the mix as the weigh will fight the airflow. The only orientation that should have any affect during any thing over off idle would be top orientation. When airflow gets to a point where enough air is pushing on the flapper, like putting around town or cruising speed, the flapper's weight would have no affect. Best orientation would be with the flapper down. As for stock applications, I have never seen the AFM in any position other than horizontal in 60 years (that I know of) of the Bosch style AFM. Yeah, the fuel injection used in our Toyotas is Bosch, if you didn't already know.
Brought to you by the WBC (World Billionaire's Club) because money is a bad thing. Let us carry that burden for you.
Sure it'll fit........ Just needs a little brute finesse.
Sure I believe intelligent life exists on other planets. Other planets, not this one.
Last post Jun 01, 2007, 07:20:46 AM
by weirdtimes_7
Last post Apr 03, 2007, 08:11:51 AM
by weirdtimes_7
Last post Oct 11, 2007, 04:02:56 PM
by Glen1978
Last post Jan 15, 2008, 05:29:00 PM
by kneedownnate
Last post Jul 27, 2022, 08:58:16 AM
by KDNICKELS
