The whole 'build to the budget' thing huh? Remember to make several retorque efforts after you install the mani. Let the engine go through 2 or 3 heat cycles ant then retorque. Keep doing that until the nuts won't retorque.
The only issue I really have about using the stock manifold is that I don't want the new studs tweaked. With the money that went into rebuilding that head I could have purchased a new one. When I torque the new nuts it will be a bit lower than the factory as per the FSM.
Crank it over. (WITHOUT the coil wire installed onto the distributor cap and the EFI fuse REMOVED) It may take 10 to 30 seconds of total cranking time to get the “oil” light to go out or your gauge (if you have an SR5 truck) to register in the ‘normal’ range.
Today since we have nice weather I hooke up more items. No plugs in and turned the engine over a couple of times, maybe 3 to 4 minutes total. I had the valve cover off. Seems like every thing is working except I expected to see more oil. I have a new mechanical oil gauge and I have no oil in the tube. Is there a way to prime the oil pump? Should I be worried or not?
Started by camoyota Project Research and Build-Ups
Started by IVrunner Toyota Pickup/4Runner Tech 1979-95
Started by Peterbuilt84 Parts Wanted
Started by Aaronm Engine
Started by MrFatEggs Toyota Pickup/4Runner Tech 1979-95
