Author Topic: 2002 3.4, 5 Speed - Can I Regear Just my stock T-Case?  (Read 1491 times)
ShapeShifter
  • Member since Sep '18
  • Another build.....ooof
« on: Aug 20, 2019, 10:33:27 AM »
New to Toyotas here.  I'm looking for slower low range but don't really need a Taco Box (however a box of tacos sounds delicious).  Is it possible to regear my low range in the transfer case?
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
No. You have a chain driven tcase. The gear driven rf1a is the case you can get 4.7 reduction gears for.
01 double cab hunting truck
06 tacoma street truck
ShapeShifter [OP]
Thanks for that input.  Its not what I was hoping to hear, but thanks.
ShapeShifter [OP]
If I were to find and install an RF1A top shift using the appropriate MC adapter plate, will I need to change driveshafts?
Team_Jake
  • Turtle Points: 476
  • Male Posts: 22
  • Member since Aug '19
It's not just a simple swap, the RF1A transfer cases are passenger-side drop, the chain drive transfer cases are driver-side drop.
There was a company called Inchworm that made driver-side drop gear-driven transfer cases where you run 4.7:1 gears, unfortunately they are no longer around. But if you keep your eyes open they pop up for sale every once in a while.
My '99 4Runner - (thread)
redneckcustoms13
  • Male Posts: 2,513
Yes would have to lengthen the front and shorten the rear drive shafts. Also have to get a "lefty" case.
ShapeShifter [OP]
 Nothin's ever easy....  :shake:
Ritchie
  • Turtle Points: 474
  • Male Posts: 219
  • Member since May '13
  • Ritchie
I suggest you look at Low Range Off-Road. Inch Worm stuff is available there.
Good luck.
'03 Prerunner, ARB's F/R w/5.29's, 4WU 3 link, Diamonds F/R, Fox shocks F/R, Shrockworks front bumper, self made rear bumper, WARN M8000S, Inchworm Lefty, Deaver 8 pack, MC sliders that hold air & a bunch of other stuff.
ShapeShifter [OP]
Good luck.
Thanks.  I already looked at low range.  All they seem to have is their Trail Creeper box which is a hundred bucks more than a Tacobox.
Ill have to keep looking for used.  All I want is 4:1 - is that too much to ask.....? :snare:
gnob
  • Turtle Points: 486
You need/want a crawl box. Quit lying to yourself
hold this. . .
ShapeShifter [OP]
But that would mean loosing one cup holder.  I need both - one for the gin and one for the tonic.
Team_Jake
  • Male Posts: 22
Triple stick...problem solved!
Team_Jake
  • Male Posts: 22
Some inspiration for you:
gnob
Gin and juice, fool
                - @SnoopDogg
hold this. . .
ShapeShifter [OP]
That reminds me of a buddy that had an Atlas transfer case in his Jeep.  He had to stop and retrain himself how to use all the different sticks everytime the trail changed.  He had like 5 different sticks.
We used to say "too many sticks, not enough marbles". LOL
Ritchie
  • Male Posts: 219
  • Ritchie
I heard that after Trail Gear bought Low Range, they did not retain the partnership with inchworm. It doesn't look like inchworm is in business right now.
Good to know... too bad for Inch Worm.
redneckcustoms13
  • Male Posts: 2,513
Inchworm made some good stuff. I had a blinged out 2wd a340 with their adapter to a 4.7 case in one of my previous rigs.
Ritchie
  • Male Posts: 219
  • Ritchie
Same here... my A340 has a shift kit which helps.  The 4.7's rock.
This pic was when I was still IFS.  That is no longer the case.
Northboundtundra
  • Turtle Points: 31
  • Member since Sep '19
  • Northbound Tundra
I just had to do a driveline modification and it was surprisingly painless. I replaced the a340f with an r150f in my tundra and since everything came out about 2” shorter I had lengthen my driveline. It cost $350 to retube it, replace the carrier bearing, and replace the old ujoint.
I still have a chain driven t case so I’m stuck with the same gearing as you but I like having a manual transmission.
2001 A/C Tundra with 2UZFE v8 and R150F 5spd manual transmission swap
Last post Jan 27, 2008, 11:42:24 AM
by kneedownnate
Last post Mar 12, 2006, 08:35:13 AM
by 79coyotefrg
Last post Jul 06, 2011, 12:25:49 PM
by safetydang
Last post Apr 28, 2014, 07:07:28 AM
by roadtrip2u
Last post Aug 08, 2017, 08:32:50 AM
by 1980firstgen20r
