Author Topic: 91 Toyota 4x4 Tire Gear Question  (Read 2796 times)
Grimmjow
  • Member since Jul '19
« on: Jul 29, 2019, 08:30:43 AM »
Hey everyone. I have read the faqs and the wheel tire thread.
I just have a question about what I have read. Iirc 31x10.50x15 will require re gear to 4.56 gears and 33s will require re gear to 4.88s? Thanks
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
Re: 91 Toyota 4x4 Tire Gear Question
« Reply #1 on: Jul 29, 2019, 10:28:41 AM »
If you have a 5-spd, and want stock performance, that is correct gearing.  You can find both gear sets in oem geared diffs.
Grimmjow [OP]
« Reply #2 on: Jul 29, 2019, 01:25:00 PM »
What difs am I specifically looking for? Can I use the difs I have and install the lower gear sets or is there a carrier difference? Thanks
Grimmjow [OP]
« Reply #3 on: Jul 29, 2019, 01:43:18 PM »
I found this while searching. If its correct please inform me. Thanks again for your help.
These differentials seem to have come in a few different Toyotas. Combos for 4.88s we’ve seen are:
‘92-‘95 4Runner, IFS, V6, 31” tires, auto transmission, tow package
‘92-‘95 pickup, IFS, V6, 31” tires, auto transmission, tow package
The vehicle will also usually have:
door tag code of G144
white pinion paint code - the end of the pinion (driveshaft removed) will have paint on it
It seems that these are the most common combos, but there are also reports of non-tow equipped vehicles having 4.88s. Never hurts to check!
  • Turtle Points: 5134
  • Male Posts: 4,238
  • Member since Jun '16
  • 4-wheeling vicariously.
« Reply #4 on: Jul 29, 2019, 08:25:23 PM »
It depends.  I ran 31s, 32s, and 33s with my 85 Standard Cab, 5-speed with stock 4.10 gears for 10 years.
But... as Snow said.... re-gearing for larger tires is better if you want to have your factory torque in the right RPM range and in the right trans gear position.
Snowtoy
  • Male Posts: 2,583
« Reply #5 on: Jul 30, 2019, 12:47:06 AM »
The available years for the G144 gears, should be '89-95(non-Taco) trucks and '90-'95 4-Runners that came w/31's, the 31" tire package was offered for the '90 model year trucks and 4 Runners, not sure if it was offered for the '89 model year trucks or not.
G254 is for the 4.56 gear set, and came in manuals with 31's, and at some point 2nd gen 4-Runners with autos instead of 4.30's, my sister's'95 had SR5 had them.
CORRODED
  • Shoutbox Ban
  • Turtle Points: -1
    • Please ban me!
          OK!
      I am banned!
« Reply #6 on: Jul 30, 2019, 12:01:18 PM »
You can install those the gears you want in your differentials, you just have to order the appropriate gear set
helipilot77
  • Turtle Points: 1018
  • Male Posts: 1,728
  • Member since Jul '12
  • Seattle, WA
    • My build thread
Grimmjow [OP]
« Reply #8 on: Aug 05, 2019, 07:55:56 AM »
Thanks for the info guys. I will put it to good use.
clange
  • Turtle Points: 39
  • Member since Jun '18
« Reply #9 on: Aug 21, 2019, 08:45:21 PM »
The above is correct. I have a 1993 4Runner, IFS, V6 (Now converted to the 3.4), 31" tires and Auto Transmission with 4.88's.
  • Turtle Points: 1174
  • Male Posts: 5,053
  • Crawlin with Marlin
« Reply #10 on: Aug 24, 2019, 06:40:10 PM »
I ran 4.10 gears with 32s in my ‘85 truck and was happy with its performance in Colorado (i.e. mountain passes). I was in Washington State when I went to 33s and almost immediately made the jump to 4.88 gear.  I now am running 35s with the same differentials in my ‘89 4Runner SAS.
Last post Mar 05, 2008, 06:16:40 PM
by toyotamobing
Last post Oct 17, 2010, 11:22:02 AM
by 12GA.YOTA
Last post Jul 07, 2011, 06:12:05 PM
by twistedtoy92
Last post Mar 11, 2013, 07:13:25 PM
by H8PVMNT
Last post Aug 24, 2015, 09:52:17 AM
by mdtrail-toy
