Author Topic: A/C clutch not working  (Read 1631 times)
TheMadRedneck
  • Turtle Points: 163
  • Member since Jul '18
« on: Jul 15, 2019, 07:03:34 AM »
I have an 85 4Runner with factory A/C.  The compressor clutch engages when I jump the wire, but will not come on without it.  Is there a high pressure switch and if not what could be wrong?  Thanks.
No Gods or Goddesses, No Masters
Toybrota
  • Turtle Points: 166
  • Male Posts: 764
  • Member since Dec '15
    • Buy me some coffee
Re: A/C clutch not working
« Reply #1 on: Jul 15, 2019, 07:51:44 AM »
Did you check the associated fuses and wiring? I believe there is a high pressure switch, located with the evaporator? I could be wrong, I don't have AC but I've read up on it because I want it.
There's a sub harness the switch connects too, I'd check there first. Switch could be bad too.
Sent from my PH-1 using Tapatalk
TheMadRedneck [OP]
« Reply #2 on: Jul 15, 2019, 04:17:45 PM »
I know that you have to have a certain amount of refrigerant pressure for the system to engage so it may be low
The A/C blows cold when the clutch is engaged.  The pressure is fine.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #3 on: Jul 15, 2019, 06:19:50 PM »
There's a fuse behind the glove box.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
TheMadRedneck [OP]
« Reply #4 on: Jul 17, 2019, 05:41:21 PM »
ok, I did not know it was blowing cold when jumped. do you have a factory service manual?
I PM'd you
Huge thanks!!  I’ve been looking for one.
TheMadRedneck [OP]
« Reply #5 on: Jul 24, 2019, 05:38:05 PM »
I PM'd you
I found the A/C circuit in the manual and thought it was probably the low pressure switch since it was also not idling up when the A/C was on.  I jumped the switch and the A/C came on.  Thanks for the help.
Last post Mar 20, 2005, 08:09:58 AM
by 79coyotefrg
Last post Jul 07, 2007, 06:50:18 PM
by Zoomschwortz
Last post Aug 18, 2008, 02:18:58 PM
by BigMike
Last post Dec 23, 2008, 01:30:45 PM
by 83MT
Last post Sep 21, 2009, 03:13:32 PM
by Larryb
