Nice, You should swap out your non vacuum axle disconnect to the new third assuming your was non. Cleans things up a bit and easy to do.
You have to swap that complete tube where it mounts to the diff. Yank the axle, and pull the tube. Takes about 20 minutes
Yep, gotta make it all the same
I used a motorcycle tire tool. The main thing is take your time and dont damage the sea.
