Why would you ever need to drop the clutch at 3,000 rpm with dual cases?
You are aware that dual cases requires driveshaft modifications and sometimes rotating the rear differential? There's more to the cost than the crawl box.
That's exactly the point: I wouldn't. As far as I can tell (admittedly not very far) the stock Toyota drivetrain is stronger than most things the 22R can put out, even if driven by a fool with a heavy foot. I regard this as a very valuable feature that I do not want to compromise. So I feel it useful to discuss the survivability of events that would very seldom happen in the real world, just to keep on the strong and safe side.I was planning on the driveshaft modifications, hadn't thought about rotating the rear diff.
Started by Bazzi General 4WD Discussion
Started by crawlerdan Parts For Sale
Started by wampum Parts For Sale
Started by John Doe Parts For Sale
Started by crazymoritz97 Axle/Differential/Steering
