I am currently fighting with this exact setup on my brothers cj-7 with AMC 258. It has been nothing but problems. I will list them to keep them organized as there are a few.1. Proprietary parts - Injectors, TPS, Fuel pressure regu8lator ect. As far as I can tell these are not off shelf parts. If they are Holley will not assist you with finding replacements. They want you to send the whole thing back to them to "service " it. Which equals 2 weeks down time.2. IT IS NOT PLUG AND PLAY! In the advertisements Holley states you don't need a computer to get this running. That is a blatant lie. Many of the features are not accessible from the touch screen. The software is not intuitive and will take you a long time to figure out if you have never messed with tuning software before. The manual does not go over the software at all.3. We are currently using the negative side of the coil for a rpm signal and its shitty. Lots of guys out there having problems with electrical noise and interference causing it to run bad. To make this system work you need to drop another 1K+ into their special ignition system. 4. After we installed this on the jeep we had a hard timing getting it to start. Adjusted the fuel map a bunch and we got it starting and running ok. Randomly starting stalling when transitioning from throttle to idle. Over 2 weeks got worse then died completely. One injector was not spraying (both injectors should spray together). Injectors both tested good at 11 ohms. Wiring looked ok. i suspected a failed injector driver or computer. Called Holley and they wanted me to send it in to them for them to test. After initial communication a new in the box unit showed up with no explanation or communication. Installed new unit and the jeep starts on the initial fuel prime then stalled. It will not fuel after that initial start. I can jeep engine running with starting fluid. Holley is using the customer to R & D their product and they don't care how it screws over their customers. They know they have a problem but as far as I can see they have done nothing to fix it.5. The computer is attached to the injection unit and is sealed with a resin of sorts so you cannot inspect the board. All so exposes the board to a lot of heat, moisture and vibration. Terrible engineering in my opinion.6. The injectors feed into two rings that have a few tiny holes drilled into them in a poor attempt at better atomization. This is a lost cause as the injection holes are ABOVE the throttle blades. So the fuel just puddles on the throttle blades at idle anyways.If there is a OEM injection manifold (or you can modify the carb manifold to accept injectors) then this is the way to go. Your going to have to learn how to tune anyways so you may as well build a Mega squirt engine management system for it. In the end you will be WAY ahead in money spent and you can get off the shelf parts to fix it when the need arises. Hope this helps lol5. After it is all said and done you will spend the same or more to get it running right then you will spend on a proper high end fuel injection system. You are getting what you pay for here.
Disclaimer: I'm copying my original post and pasting to multiple forums so that I don't have to type so dam much.
Disclaimer: I'm copying my original post and pasting to multiple forums so that I don't have to type so dam much.You probably have it all sorted out by now but for those who are looking to make the swap, this may help. I have the sniper 2300 efi setup on my 22r and absolutely love it. However, fair warning -- there is a HUGE learning curve with this setup. Firstly, you'll need to port the intake manifold so that the adapter relays a smooth transition. More on general setup here: https://www.youtube.com/watch?v=Nu_ixe1YGCM&t=235sand here: https://www.youtube.com/watch?v=x4f3p-LWmjMThat should get you started. What these videos don't tell you is that the sniper will need to be tuned. Holley claims these setups are "self-tuning." That couldn't be further from the truth. Once you set the carb to learn, you'll need to drive around a bit and tell it to transfer what the carb has learned to your base fuel map. Doing this multiple times will start to make your 22r run better although, it doesn't end there. This can be on the handheld or through sniper program on your computer. That said...You should download the sniper software to install on your computer. That can be found at Holley.com. Same is true for updating the handheld's SD card contents: https://www.youtube.com/watch?v=IR1KC4qcewUKeep in mind that even if you go through this incredible learning curve, it still won't beat taking your rig to get professionally tuned. That's why the "self-tuning" claim made by Holley is a murky claim at best. But if you're dead-set on DIYing this like I did, this video is without a doubt one of the better tutorials out there: https://www.youtube.com/watch?v=cviwJki7olk&list=LL&index=25Here are a couple more that were also helpful to me: https://www.youtube.com/watch?v=T6ppzR0lfXk&list=LL&index=27https://www.youtube.com/watch?v=FpBwK8Tdqpc&list=LL&index=26Also, I don't have my setup connected to the distributor so the carb isn't controlling my timing. It hasn't been a big deal for me though but you should make sure to have your timing squared away before all is said and done. Hope this helps!
No problem! I haven't had any issues with mine yet and I frequently drive on the highway. It's worth noting however, that the master kit comes with an obnoxiously loud electronic fuel pump so it may be worth considering a different pump or using the standard mechanical pump 22rs come with.
how many miles you put on that sniper?
Started by olivedrabcj7 Rigs For Sale
Started by 84socal Chit Chat Camp
Started by Jaysen Rigs For Sale
Started by 4runner4x4 Rigs For Sale
Started by Toymin8r Chit Chat Camp
