what are you trying to do? save a damaged block or build a hot rod?
.... So my idea is a 22R powerband, all in by 5000rpm with stump pulling torque.
Yep, been there, done that. I've built 200+hp 20/22r engines for my Celicas.
.... Definitely not worth it, but maayybee……. See how crazy I get about this idea.
200-225tq at 2400-3000rpm is what I was looking at depending on cam and head. Hp would be 160-170 in the 5000-5700rpm range, again head and cam.
This is all just an idea right now ... My '7AGE' is taking me 7 years to build...
... 200-225tq at 2400-3000rpm is what I was looking at depending on cam and head. Hp would be 160-170 in the 5000-5700rpm range, again head and cam. Using the 22R head will help with the lower range, 20R head will work better mid to high end, if you can call 5000rpm high.
Started by TonkaTaco New Member Check-In!
Started by chevyLUVtoyota Engine
Started by BLUCRUZ Engine
Started by Sundowner Parts For Sale
Started by E YOTA Project Research and Build-Ups
