Author Topic: 1985 4runner no low beams only high beams  (Read 2870 times)
337junk
  • Turtle Points: 117
  • Member since Apr '19
« on: Apr 29, 2019, 10:41:44 AM »
ok so i recently picked up this rig and have been undoing a bunch of b.s. done to it by previous owner. it had some old out dated led headlights that didn't work. i pulled those how and put brand new sealed beams
in it. none of the original wiring was hacked into for the headlights. so with new headlights i only have high beams no low beams. all fuses are good, headlight relay is new. both old and new relay click when turning
on the headlight switch. not sure what to chase from here. any suggestions are greatly appreciated. thank you
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
Re: 1985 4runner no low beams only high beams
« Reply #1 on: Apr 29, 2019, 12:56:12 PM »
Do you have power from the relay when the switch is turned on? If so there is an issue with the wiring between the relay and the head lights
Procedure for testing combination switch
337junk [OP]
« Reply #2 on: Apr 30, 2019, 10:31:31 PM »
thanks for the tip. I will try checking that.
NotPossible907
  • Turtle Points: 261
  • Member since Sep '18
« Reply #3 on: May 23, 2019, 01:10:26 PM »
Something else to keep in mind is alternating power and ground. Just went through this with my pickup. Not 100% sure about the 85+s, but on my 80, and my 81 there is always power to the headlights. When you turn the switch on, it supplies a ground for the current. When you turn on your high beams, the ground that is used is changed. Double check that your headlights are alternating ground from the factory as well as the new ones. If the new ones are alternating power, you can either make a relay harness with 2 relays getting power from something that is only on when the engine is running, like the alternator post, use your alternating ground to give one relay or the other power, which would send power to the new headlights.
Once you know if you have double ground, or double power harness and lights I can make up a diagram to show you what you need to do if they are different.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #4 on: May 25, 2019, 05:23:30 PM »
Here is a good write up on repairing the Headlight Combo Switch:  http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#Headlight_Combo
Last post Mar 01, 2007, 06:50:30 AM
by olemisstoy88
Last post Jun 20, 2007, 09:09:00 PM
by abriel68
Last post Jan 30, 2012, 11:56:14 AM
by Hunterwarren
Last post Feb 03, 2015, 05:36:41 PM
by hodge built
Last post Dec 17, 2020, 02:32:37 AM
by floramary380
